Said-R
  • 23
Message 31 of 49
Re: NEW TO VIGIRN MEDIA - Broadband M500 - is on 1.63Mbps - HELP
Network Log Tab:   Network Log
16/01/2021 13:20:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 12:42:36Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 20:04:20noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 14:06:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:16:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:16:56ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:48Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 17:09:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (1)
Ve33iE
  • 8
Message 32 of 49
I can see your from your downstream that your levels are bit too high +10 will put you out of spec from a engineers point of view - An engineer will need to be called out
Said-R
  • 23
Message 33 of 49
can you explain,
i dont understand why the engineers wil be needed to be called out,
what would he do to make it better?
Tags (1)
conman33158
  • 1.28K
  • 109
  • 240
Superfast
Message 34 of 49
The engineer will NOT be called out, it is Virgin over selling to customers and too many people on the same network, nothing can be done by an engineer. You will have to wait until Virgin expand the network in your area which can take months or not at all. You either live with it or change to another ISP.
Said-R
  • 23
Message 35 of 49
How do I change ISP?
conman33158
  • 1.28K
  • 109
  • 240
Superfast
Message 36 of 49
ISP (Internet service provider) BT, Talk Talk etc
Said-R
  • 23
Message 37 of 49
oh no i rather wait
  • 22.06K
  • 2.36K
  • 3.94K
Message 38 of 49
When did you "join" - are you still within your 14-day "cooling-off" period?
Said-R
  • 23
Message 39 of 49
i joined on 12 Jan 2021
conman33158
  • 1.28K
  • 109
  • 240
Superfast
Message 40 of 49
@Said-R wrote:
oh no i rather wait
That's fine and the choice is entirely up to you, but just be aware that you might be waiting a long time.
