forumarchive,nothingtosee,
Said-R
  • 23
Message 1 of 49
NEW TO VIGIRN MEDIA - Broadband M500 - is on 1.63Mbps - HELP
I recently got Virgin Media box and Broadband installed by the technician but unfortunately the signal was poor from the green box outside and he said that someone would come and fix the issue outside, the technician left me be with no instructions after and was on the phone to Virgin Media for 30 mins today no answer
Yesterday  I got a texted that it’s now sorted but I went to my WiFi and did the spreed test and got download- 1.63Mbps and Upload speed - 0.41Mbps
Now I am new to this so if I need to set up properly please can you go easy and explain how to do it right everything is tightened as I haven’t touched the wires
if I need to show something please can you show me exactly how to show it to you all
thanks in advance!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 49
Re: NEW TO VIGIRN MEDIA - Broadband M500 - is on 1.63Mbps - HELP
Reboot your Hub.
then
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Said-R
  • 23
Message 3 of 49
Thank you for reponding,
here is what i got
one te computer (WiFi):
Latency
25.8 ms
Jitter
4.80 ms
Download
1.94 Mbps
Upload
494 Kbps
On the Xbox One (Ethernet Cat 6 Cable)
Latency
23.6 ms
Jitter
6.16 ms
Download
2.20 Mbps
Upload
462 Kbps
 on the Connected Devices page it shows this:
Connected devices
All devices connected to your Hub 3.0 are listed below:
Device name MAC address IP address Speed (Mbps) Connected to
Virgin-TV**:**:**:**:**:**192.168.0.11/24846.38WI-FI 5G VM6065163
XBOXONE**:**:**:**:**:**192.168.0.14/241000Ethernet
SaidResdsiPhone**:**:**:**:**:**192.168.0.12/24761.71WI-FI 5G VM6065163
Saids-iMac**:**:**:**:**:**192.168.0.10/24856.93WI-FI 5G VM6065163
hope it helps
Said-R
Tags (1)
conman33158
  • 674
  • 63
  • 86
Superfast
Message 4 of 49
You need to run the test from a PC direct to the router with a Cat 5e cable or better, the Xbox and Wifi is not good for proper test results.
Said-R
  • 23
Message 5 of 49
i changed the cable with is a Cat 6 to the computer this is what i got
Latency
23.8 ms
Jitter
5.80 ms
Download
1.93 Mbps
Upload
454 Kbps
and the contected devices page:
Saids-iMac**:**:**:**:**:**192.168.0.15/241000Ethernet
hope that helps
Tags (1)
conman33158
  • 674
  • 63
  • 86
Superfast
Message 6 of 49
Mikerobbo will be along to advise you on your next move mate, this will probably involve putting up your router stats and setting up a BQM 🙂
Said-R
  • 23
Message 7 of 49
thank you, but i have no idea what that means
but thanks for letting me know
regrads
Said-R
Tags (1)
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 8 of 49
regrads
Said-R
Create a BQM and post the live link.
It creates a graph showing your line quality.
Said-R
  • 23
Message 9 of 49
i dont no if i did it right but here you go
https://www.thinkbroadband.com/speedtest/1610807526574276355
Tags (1)
conman33158
  • 674
  • 63
  • 86
Superfast
Message 10 of 49
Go here and create a new monitor https://www.thinkbroadband.com/broadband/monitoring/quality
