acollins118
My speed is not what i'm paying for RG
Hi, I've tried getting through to someone on the phone and given the times at the moment I understand that it's difficult, but being on hold for on and off 3 hours is not great, when every 15 min I have to re phone cause it gets disconnected, so I thought I'd try on here.
My internet has been on and off decent over the lockdown period and again, I can understand the extra stress the network must be under, however its gotten to the point that I can't do anything online now at the time of posting this my speed is supposed to be 200mb.
I feel like its not on when its been like this for over a week. and yet if I decided to pay less this month I'd just get cut off. I've done all the standard things for fixing the network on my end, and given other households in my area are having the same issue on VM I kind of think the issue is on your end
Tags (3)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: My speed is not what i'm paying for RG
How are you connecting your device, Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
