The error values should reset when you reboot.
I'm not sure how many changes you've made to the hub settings since acquiring it, however I would suggest trying a full reset (Pin hole for at least 30 - 60 seconds). Keep in mind this will restore the hub to factory defaults (Password to sign in, etc.).
You either have a faulty hub or a very noisy line.
