I'm in West Ealing, London, W13, and over the last six weeks i have been experiencing issues with multiple dropouts and daily errors on my connection, most of which are marked as critical.
From the basic logs on my Superhub 3 I get the following errors
11/02/2021 17:56:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/02/2021 16:44:58 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/02/2021 00:36:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/02/2021 00:35:46 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/02/2021 00:32:57 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/02/2021 00:32:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/02/2021 00:24:1 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/02/2021 20:45:37 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/02/2021 20:18:6 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/02/2021 20:10:48 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/02/2021 19:41:1 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/02/2021 17:43:2 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/02/2021 07:54:46 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/02/2021 21:58:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/02/2021 13:07:33 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/02/2021 16:48:3 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/02/2021 16:48:3 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/02/2021 16:47:3 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/02/2021 16:47:3 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/02/2021 16:45:23 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
The additional information which may be of use to solving my issues I have listed below
Hub 3.0 device information
The information below shows current status of this Hub 3.0.
Standard specification compliant | : DOCSIS 3.0 |
Hardware version | : 10 |
Software version | : 9.1.1912.304 |
Cable MAC address | : **:**:**:**:**:** |
Cable modem serial number | : AAAP82280716 |
System up time | : 1 days 3h:13m:18s |
Network access | : Allowed |
Acquired Downstream Channel (Hz) | 330750000 | Locked |
Ranged Upstream Channel (Hz) | 53700000 | Locked |
Provisioning State | Online |
1 330750000 13.5 40 256 qam 25
2 202750000 13.3 40 256 qam 9
3 210750000 13.3 40 256 qam 10
4 218750000 13.1 40 256 qam 11
5 226750000 12.9 40 256 qam 12
6 234750000 12.8 40 256 qam 13
7 242750000 12.6 40 256 qam 14
8 250750000 12.4 40 256 qam 15
9 258750000 12.5 40 256 qam 16
10 266750000 13 40 256 qam 17
11 274750000 13 40 256 qam 18
12 282750000 13.3 40 256 qam 19
13 290750000 13.3 40 256 qam 20
14 298750000 13.4 40 256 qam 21
15 306750000 13.1 40 256 qam 22
16 314750000 13.4 40 256 qam 23
17 322750000 13.5 40 256 qam 24
18 338750000 13.5 40 256 qam 26
19 346750000 13.5 40 256 qam 27
20 354750000 13.6 40 256 qam 28
21 362750000 13.5 40 256 qam 29
22 370750000 13.1 40 256 qam 30
23 378750000 12.5 38 256 qam 31
24 386750000 12.1 40 256 qam 32
1 Locked 40.3 28 0
2 Locked 40.3 19 0
3 Locked 40.3 12 0
4 Locked 40.3 10 0
5 Locked 40.3 7 0
6 Locked 40.3 7 0
7 Locked 40.9 13 0
8 Locked 40.3 8 0
9 Locked 40.3 8 0
10 Locked 40.3 8 0
11 Locked 40.3 11 0
12 Locked 40.3 13 0
13 Locked 40.3 12 0
14 Locked 40.3 12 0
15 Locked 40.9 5 0
16 Locked 40.3 22 0
17 Locked 40.9 22 0
18 Locked 40.3 25 0
19 Locked 40.3 25 0
20 Locked 40.3 25 0
21 Locked 40.3 11 0
22 Locked 40.3 10 0
23 Locked 38.9 17 0
24 Locked 40.3 91 209
1 | 53700000 | 34.3 | 5120 | 64 qam | 2 |
2 | 39400000 | 34.3 | 5120 | 64 qam | 4 |
3 | 46200000 | 34.3 | 5120 | 64 qam | 3 |
4 | 60300000 | 34.3 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | JKDHSUBsgvca69834ncxv9873 |
SFID | 18176 |
Max Traffic Rate | 117000047 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 18173 |
Max Traffic Rate | 10500047 |
Max Traffic Burst | 16320 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
The network diagnostic tool seems happy enough when its available, but when the connection drops I am unable to access it to check.
This is my first account with VM, so any assistance you can give would be much appreciated
