June58
  • 12
Message 1 of 10
Much slower after supposedly doubling my speed.
I phoned for a better deal last Friday. Got my package for £2 cheaper & you were supposed to be upgrading my BB speed from 125 to 250. It now seems to be very much slower. Any reason why this has happened?
  • 1.94K
  • 125
  • 447
Super solver
Message 2 of 10
Re: Much slower after supposedly doubling my speed.
Whenever we have a service speed change the Hub needs a reboot for the speed change to become active.
This link will test the speed to the Hub : https://www.samknows.com/realspeed/
June58
  • 12
Message 3 of 10
I do not leave my hub on unless I am using the internet so my hub is rebooted regularly. I tried phoning Virgin but all they did was text me a link to my mobile which I could not use because I do not have a smartphone & the link was sooooooo long I couldn't type it into my laptop.
  • 1.94K
  • 125
  • 447
Super solver
Message 4 of 10
If you are reading this on a laptop just click on the link :  https://www.samknows.com/realspeed/
venables
  • 124
  • 19
Up to speed
Message 5 of 10
Turning off the hub constantly actually wont help - they tend to stabilise to their best speed over a period of time. I had a new Hub installed today, and although the speed was good as soon as it started it only really got a reliably fast (top-speed for my connection) download after 20-30 minutes.
Generally all modems are the same - there is a fair bit of handshaking that goes on between the modem and the Virgin/BT/whoever's kit to determine what the line speed actually is and they gradually work up to it so that they can achieve a nice, reliable and stable connection.
  • 1.94K
  • 125
  • 447
Super solver
Message 6 of 10
Dynamic Line Management is a best efforts feature of Openreach xDSL services over telephone lines.
Virgin Media's DOCSIS system does not do this.
  • 13.9K
  • 1.08K
  • 2.82K
Message 7 of 10
Once the hub has ‘handshaked’ with the CMTS to get the appropriate channels your speed should be as specified in the hub settings. There is no bedding in period.
June58
  • 12
Message 8 of 10
I don't leave my hub switched on cos I don't use broadband 24/7 & I'm trying to use as little energy as possible cos of the high energy bills.
Until I changed/upgraded my Virgin Package, my old 125 speed was faster than what I have now, supposed to be 250.
My speed has never been fantastic but it was certainly better before I was 'supposedly' upgraded.
venables
  • 124
  • 19
Up to speed
Message 9 of 10
Thanks for the info, I will remember that. It did take some time for mine to get back to 600Mbps as the engineer hung about until it got there so I will keep an eye on it
Gareth_L
  • 11.5K
  • 635
  • 1.26K
Message 10 of 10
Hello June58.
Thanks for your post.
Sorry to hear about the issue with your speeds after the upgrade.
I have ran a test on your Hub from here and you only have 1 upstream and 1 downstream channel.
In easy terms we need to get an engineer out.
I can look into arranging this for you.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
