Stanl
  • 164
  • 7
Message 1 of 35
Moved Home Dreadful Speed
I recently moved home to a property with Fibre Optic Broadband and a cabinet less than 100 metres from my property what more could one wish for?
Well a decent connection would be good..😂
I have a 600mb package and I am frequently recording speeds of 60-70mb so I decided to contact Virgin for help, I spoke to a clown who had no idea about what I was trying to explain and he was determined to get me off the line and send me a new 'Cable' I told him I had a brand new Cat 6e cable and was wired into the router from my laptop.
Anyway the 'cable' arrived today and it was a WiFi Pod???????
How do I get through to someone at Virgin with the Technical Ability to solve my issue or should I just report the issue as a fault?
  • 6.1K
  • 513
  • 1.57K
Message 2 of 35
Re: Moved Home Dreadful Speed
Post your power levels, Pre and PostRS errors and Network log from the Hub.   Also setup a BQM here  www.thinkbroadband.com/ping
Once done we can comment on your circuit.
Stanl
  • 164
  • 7
Message 3 of 35
Please pardon my lack of knowledge but how do I get my power levels, Pre and PostRS errors and Network log from the Hub?
I know how to access the hub so can probably locate the network log but don’t know how to do the rest.
sorry if this seems like a stupid question but I’m not familiar with these terms but I do learn quickly
Gareth_L
  • 10.82K
  • 603
  • 1.2K
Message 4 of 35
Hi Stanl
In order to access network logs for your Hub3 here are some instructions:
1. Type 192.168.0.1 (192.168.100.1 if you are in Modem mode) into your browser URL bar and press enter.
2. When the page appears click ‘Check Router Status’
3. When the page appears, log in (using the details on the hub) and then go to Advanced Settings > Tools > Network Status.
This is where you will find the Downstream, Upstream, Configuration and Network logs. If ever you need help deciphering them, I'd recommend copy and pasting them here on forums (as opposed to prtsc/screenshotting).
Let me know if this helps
Gareth_L
Stanl
  • 164
  • 7
Message 5 of 35
Thanks @Gareth_L
I have just had an interesting chat with technical support who have told me that my device (laptop) is incompatible with the Speedtest because at their end they are recording speeds of 600+mb speeds.
My laptop is 8 months old and I used it to check the speeds in my old house and it recorded speeds way above 500mb so how on earth can it now be incompatible?
I’ve only moved 5 miles up the road onto a genuine fibre optic network and all of a sudden the device and method of checking the speeds I have been using have become out of date and incompatible.
I’m no tech wiz kid but even I don’t believe that load of BS.
Is there a way I can get a technician visit with being made to feel like the village idiot?
carl_pearce
  • 1.44K
  • 94
  • 317
Knows their stuff
Message 6 of 35
@Stanl wrote:
Thanks @Gareth_L
Post what has been requested above and we can check for you.
Gareth_L
  • 10.82K
  • 603
  • 1.2K
Message 7 of 35
Hi Stanl
Thanks for that reply, we do need to look at this.
But first can you please
let us know the Network logs like you asked for help with previously
Gareth_L
Stanl
  • 164
  • 7
Message 8 of 35
This morning my wife had an unsolicited telephone call telling her that our broadband had problems. They asked her to allow them access via TeamViewer so she rang me and I told her to hang up as I do not trust unsolicited phone calls.
After being told everything was perfect by a virgin technical support member last week I was too suspicious.
Anyway I got the following information from my router and hope it is the correct information for someone to advise me further.
Readings before logging in.
13/12/2021
17:04:28
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTSMAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2021
13:57:56
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CMMAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CMQOS=1.1;CM-VER=3.0;
08/12/2021
08:48:32
critical
No Ranging Response received - T3 time-out;CMMAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CMQOS=1.1;CM-VER=3.0;
07/12/2021
21:45:20
notice
05/12/2021
12:40:57
Error
04/12/2021
21:14:48
critical
03/12/2021
20:46:17
notice
30/11/2021
18:15:40
critical
30/11/2021
17:15:37
Error
28/11/2021
08:03:3
critical
26/11/2021
16:30:27
Error
26/11/2021
11:51:52
critical
Received Response to Broadcast Maintenance Request, But no
Unicast Maintenance opportunities received - T4 time out;CMMAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CMQOS=1.1;CM-VER=3.0;
26/11/2021
11:51:45
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTSMAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2021
11:51:41
critical
SYNC Timing Synchronization failure - Loss of Sync;CMMAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CMQOS=1.1;CM-VER=3.0;
26/11/2021
11:51:41
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTSMAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2021
11:51:41
critical
26/11/2021
11:51:40
Warning!
26/11/2021
11:51:4
critical
26/11/2021
11:51:2
Warning!
26/11/2021
11:51:2
critical
Router readings after log in.
13/12/2021
17:04:28
notice
13/12/2021
13:57:56
Error
option;CM-MAC=**:**:**:**:**:**;CMTSMAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2021
08:48:32
critical
07/12/2021
21:45:20
notice
05/12/2021
12:40:57
Error
04/12/2021
21:14:48
critical
03/12/2021
20:46:17
notice
30/11/2021
18:15:40
critical
30/11/2021
17:15:37
Error
28/11/2021
08:03:3
critical
26/11/2021
16:30:27
Error
26/11/2021
11:51:52
critical
26/11/2021
11:51:45
Warning!
26/11/2021
11:51:41
critical
26/11/2021
11:51:41
Warning!
26/11/2021
11:51:41
critical
26/11/2021
11:51:40
Warning!
26/11/2021
11:51:4
critical
26/11/2021
11:51:2
Warning!
26/11/2021
11:51:2
critical
Stanl
  • 164
  • 7
Message 9 of 35
Noticed that some text had been changed to *.* so trying again.
Before Logging In:
Time
Priority
Description
13/12/2021
17:04:28
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS- MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2021
13:57:56
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM- MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM- QOS=1.1;CM-VER=3.0;
08/12/2021
08:48:32
critical
No Ranging Response received - T3 time-out;CM- MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM- QOS=1.1;CM-VER=3.0;
07/12/2021
21:45:20
notice
05/12/2021
12:40:57
Error
04/12/2021
21:14:48
critical
Time
Priority
Description
03/12/2021
20:46:17
notice
30/11/2021
18:15:40
critical
30/11/2021
17:15:37
Error
28/11/2021
08:03:3
critical
26/11/2021
16:30:27
Error
26/11/2021
11:51:52
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM- MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM- QOS=1.1;CM-VER=3.0;
26/11/2021
11:51:45
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS- MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2021
11:51:41
critical
SYNC Timing Synchronization failure - Loss of Sync;CM- MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM- QOS=1.1;CM-VER=3.0;
26/11/2021
11:51:41
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS- MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Time
Priority
Description
26/11/2021
11:51:41
critical
26/11/2021
11:51:40
Warning!
26/11/2021
11:51:4
critical
26/11/2021
11:51:2
Warning!
26/11/2021
11:51:2
critical
After Logging In:
Refresh data
Time
Priority
Description
13/12/2021
17:04:28
notice
13/12/2021
13:57:56
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS- MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2021
08:48:32
critical
07/12/2021
21:45:20
notice
05/12/2021
12:40:57
Error
04/12/2021
21:14:48
critical
Time
Priority
Description
03/12/2021
20:46:17
notice
30/11/2021
18:15:40
critical
30/11/2021
17:15:37
Error
28/11/2021
08:03:3
critical
26/11/2021
16:30:27
Error
26/11/2021
11:51:52
critical
26/11/2021
11:51:45
Warning!
26/11/2021
11:51:41
critical
26/11/2021
11:51:41
Warning!
26/11/2021
11:51:41
critical
Time
Priority
Description
26/11/2021
11:51:40
Warning!
26/11/2021
11:51:4
critical
26/11/2021
11:51:2
Warning!
26/11/2021
11:51:2
critical
carl_pearce
  • 1.44K
  • 94
  • 317
Knows their stuff
Message 10 of 35
The hidden (starred) section is to be expected, to protect your data.
You need to post the data from all the tabs requested.
