Makakar
  • 27
Modem rebooting multiple times per day plus packet loss (Hub 3)
Had some occasional packet loss during peak times but today the Hub 3 appears to be rebooting at random times.
Can't access the Hub during these times.
Aware of the heat at the moment, but ventilation around modem is good and other network kit is working without any issues.
Hub 3 is in modem only mode.
Not sure if my forum account is linked to my VM account.
12670000002.736256 qam17
22750000002.536256 qam18
32830000002.536256 qam19
42910000002.236256 qam20
52990000002.535256 qam21
63070000002.236256 qam22
73150000002.236256 qam23
8323000000236256 qam24
93310000002.236256 qam25
103390000002.236256 qam26
113470000002.236256 qam27
12355000000236256 qam28
133630000002.236256 qam29
143710000002.236256 qam30
153790000002.436256 qam31
163870000002.236256 qam32
173950000001.736256 qam33
184030000001.736256 qam34
19411000000236256 qam35
204190000001.236256 qam36
214270000001.736256 qam37
224350000001.236256 qam38
234430000000.736256 qam39
244510000000.535256 qam40
1Locked36.300
2Locked36.300
3Locked36.650
4Locked36.310
5Locked35.7150
6Locked36.610
7Locked36.350
8Locked36.340
9Locked36.300
10Locked36.370
11Locked36.300
12Locked36.310
13Locked36.340
14Locked36.650
15Locked36.340
16Locked36.670
17Locked36.600
18Locked36.340
19Locked36.350
20Locked36.300
21Locked36.650
22Locked36.6150
23Locked36.620
24Locked35.700
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
15370000040.8512064 qam2
26030000041512064 qam1
33940000039.8512064 qam4
44620000040512064 qam3
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0020
3ATDMA0000
4ATDMA0000
Makakar
  • 27
Re: Modem rebooting multiple times per day plus packet loss (Hub 3)
Can't see the edit button on mobile, but just had another outage around 23:12.
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Power and SNR levels look fine - VM will need to do some digging around to see what is going on!
Post up your actual network log (far right tab in the hub stats)
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum!
Makakar
  • 27
Forgot about the graph, looks like my IP changed so it's missing data from yesterday.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d46eab3279255ea299fa0a1d0868d07a9f...
Managed to catch it going down, all lights seem to flash red then seems to go through a boot cycle (edgerouter gets the 192.168.100.1 address then gets the external IP).
Logs are below (doesn't look like much):
01/07/2021 16:37:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 23:14:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 17:28:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 13:00:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 13:00:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 13:00:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 09:04:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/06/2021 02:26:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2021 09:06:41Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 04:49:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 04:49:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2021 02:35:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2021 23:03:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2021 14:46:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/05/2021 23:03:39ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/05/2021 17:25:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/05/2021 12:01:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2021 19:34:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/05/2021 23:03:41ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 09:08:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Makakar
  • 27
Confirmed its definitely the hub restarting, doubled checked the lights on a boot by pulling the power and it's exactly the same, seems to be increasing in frequency as well.
Ayisha_B
  • 1.41K
  • 49
  • 132
Hi @Makakar,
Welcome to our Community Forums and thanks for posting.
I am sorry to hear you are having problems with the service. I have located your account and everything looks good this end.
Can I ask you to factory reset the hub and let us know if you notice any improvements thereafter?
Ayisha_B
