me_plus_one
  • 12
Missing about 10% speed
Have had many years of uninterrupted service on the M100 package, recently re-contracted to broadband recently, however it may be a coincidence but I'm getting about 90 downstream instead of the usual 106 etc.
My equipment hasn't changed, the VM hub 3.0 is in modem only mode as ever and using a wired connection using the closest servers on speedtest and also ones further away just incase there was a problem. I have tried testing at different times of the day but its coming out at 90 odd instead of what is being paid for which is 100 downstream.
Do the levels look ok?
13230000001.738256 qam24
22030000000.537256 qam9
32110000000.437256 qam10
42190000000.537256 qam11
52270000000.437256 qam12
62350000000.538256 qam13
72430000000.538256 qam14
82510000000.538256 qam15
92590000000.738256 qam16
102670000000.938256 qam17
112750000000.738256 qam18
122830000001.238256 qam19
132910000001.238256 qam20
142990000001.738256 qam21
153070000001.938256 qam22
163150000001.538256 qam23
173310000001.538256 qam25
183390000001.738256 qam26
19347000000238256 qam27
203550000001.938256 qam28
213630000002.238256 qam29
223710000002.438256 qam30
233790000002.238256 qam31
243870000002.438256 qam32
1Locked38.6210
2Locked37.6150
3Locked37.6110
4Locked37.690
5Locked37.6100
6Locked38.6230
7Locked38.680
8Locked38.6480
9Locked38.6110
10Locked38.6160
11Locked38.9320
12Locked38.6320
13Locked38.9360
14Locked38.9170
15Locked38.990
16Locked38.9320
17Locked38.6250
18Locked38.680
19Locked38.980
20Locked38.6180
21Locked38.9220
22Locked38.9230
23Locked38.6190
24Locked38.970
carl_pearce
  • 1.76K
  • 114
  • 378
Super solver
Re: Missing about 10% speed
Could you try a different ethernet cable between the HUB and device you are using?
It sounds like the link speed may have dropped from 1Gbps to 100Mbps (Max of 95Mbps including overheads).
Downstream levels look ok, however it is worth posting upstream data.
  • 20.48K
  • 828
  • 2.2K
What own router do you have?
If link speed shows 1Gb and you can test with a PC to hub in modem mode then the internal is broken at 100Mb in the hub.
me_plus_one
  • 12
@carl_pearce you were right to suggest this, I made the basic error in not checking the device I was using, it was limited to 100Mbps not 1Gbps, then tried two other devices rated at 1Gbps and they work to the full speed.
me_plus_one
  • 12
@legacy1 you were right to suggest this, I made the basic error in not checking the device I was using, it was limited to 100Mbps not 1Gbps, then tried two other devices rated at 1Gbps and they work to the full speed.
Paul_DN
  • 10.7K
  • 546
  • 1.09K
Hi me_plus_one,
Thank you for reaching out to us in our community and welcome back, sorry to hear you have recently noticed a 10% drop in your speed compared to what you have been receiving, it is frustrating after having no issues previously, I have been able to locate you and had a look our end and cannot see any issues at all, have you been able to try a different Ethernet cable and maybe try a different port on our Router, if this doesn't help try doing a pin reset on the Hub to rule out a software issue, push a pin/ paper clip in the reset hole at the back of the Router, push and hold in for a timed 1 Minute, do not reboot during or after, allow 15 Minutes to settle, once done put it back into Modem mode and reconnect your Router.
Paul.
