@Kaleem71 wrote:
Are the tp link deco any good not looking to spend a fortune as i have a 2 bedroom house
Yes they are a great solution for most average users. I have 3 friends who swear by them. To do it on a "budget" look at a 2-pack of the M4 or S4 units. If that doesnt sort it completely then you can always add a third unit later. Albeit it will work out cheaper if you go for the 3-pack first (still under £100).
Whichever you choose then check back here (or search forum) to get the correct set up "sequence".
