  • 8
Message 1 of 14
Max speed 109mbs not 500
Currently getting DL speed of 109mbs I should be getting 500mbs site visit mate connection and speed are fine any suggestions ?
  • 15.61K
  • 1.63K
  • 2.66K
Message 2 of 14
Re: Max speed 109mbs not 500
On one device or all devices?
What are they?
Are they connected wired or wifi?
Are the devices gigabit enabled?
  • 8
Message 3 of 14
Tested on 5 devices phone, pc,laptop,tablet and 2nd phone tried WiFi and enet. Pc and laptop are gigabit and connection info confirms in router device's
  • 15.61K
  • 1.63K
  • 2.66K
Message 4 of 14
OK do this.
If you think that you have a BB speed problem, then to check the speeds coming in to your Hub properly, and whether they match what you should be getting, you cannot rely on wifi tests, you need to do it on an ethernet cable connected computer/laptop with the Hub in modem mode.
So... make sure that your device has a gigabit network card (not a 10/100 one or one that is “limited to that in its settings) and has the most up to date drivers. Use a new Cat6a ethernet cable (old ones do "fail" and Cat6 is best) to connect it directly to the Hub - which you have put into modem mode (see VM website for "how to") this ensures only your one device is connected. Check speeds like that first.
If they are still low - then, boot up your device into "safe mode with networking" (to disable any software on it that could be limiting speeds - lots do!). Run the speedtests at speedtest.net (try on x2 close VM servers) using 2 different browsers preferably with one of which is a fresh download of one you haven’t previously used (e.g. Firefox, Opera, Safari etc - there are several reports on here of certain browsers causing speed issues).
Try that and report back what you get.
  • 14.85K
  • 1.17K
  • 3.47K
Message 5 of 14
cat5e cables are perfectly good enough - no idea where this fixation for cat6 and above cables has come from
have you had better speeds in the past
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
  • 15.61K
  • 1.63K
  • 2.66K
Message 6 of 14
Tony - my particular "fixation" is kippies derived 😀   See the discussion at the end of this older thread.  It may be anecdotal and not scientifically valid but it is firmly lodged in my hind brain until something shifts it.
https://community.virginmedia.com/t5/Networking-and-WiFi/ethernet-connection-floating-between-20-and...
  • 14.85K
  • 1.17K
  • 3.47K
Message 7 of 14
how can i criticise another VIP - but he is wrong imo - he - as we all are are entitled to our opinions in this i think he is playing far too safe
i agree that if you are starting with nothing for the little extra cost then why not go for a cat6 but the argument to only use them or change to them from cat5e is mute - thats my opinion for what its worth
Tony
  • 8
Message 8 of 14
Thanks chaps I'll give it a try this evening and see what I get.
Previous test have been done over cat 5 and cat 6 running at 1000mbs
Also to add speed test over WiFi had came back 483mbs 3 days ago
  • 30.33K
  • 1.51K
  • 5.27K
Message 9 of 14
Cat5e is designed for 1000mbps over 100meters
cat6 is only required for 10gbps ethernet. So it is not needed. Cat5e is fine and will not make any problems at gigabit speeds
  • 8
Message 10 of 14
  Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1475000000-2.238256 qam31
21950000000.238256 qam8
32030000000.238256 qam9
42110000000.238256 qam10
52190000000.238256 qam11
6227000000038256 qam12
7235000000-0.238256 qam13
8243000000-0.438256 qam14
9251000000-0.538256 qam15
10259000000-0.438256 qam16
11267000000-0.238256 qam17
12275000000-0.438256 qam18
13283000000-0.238256 qam19
14291000000-0.238256 qam20
15299000000-0.238256 qam21
16307000000-0.438256 qam22
17315000000-0.538256 qam23
18323000000-0.738256 qam24
19427000000-138256 qam25
20435000000-1.238256 qam26
21443000000-1.438256 qam27
22451000000-1.438256 qam28
23459000000-1.538256 qam29
24467000000-238256 qam30
1Locked38.660
2Locked38.960
3Locked38.980
4Locked38.660
5Locked38.670
6Locked38.660
7Locked38.680
8Locked38.680
9Locked38.990
10Locked38.650
11Locked38.960
12Locked38.680
13Locked38.960
14Locked38.670
15Locked38.680
16Locked38.9200
17Locked38.680
18Locked38.640
19Locked38.660
20Locked38.980
21Locked38.6200
22Locked38.6140
23Locked38.6110
24Locked38.613
0
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1462000194.9512064 qam3
2394000194.9512064 qam4
3536999694.9512064 qam2
4603000174.9512064 qam1
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
