Massive packet loss for the past few days
AurelC2G
I've been with Virgin Media for a year and a half and it worked mostly without any issues (though the speed I'm getting is significantly lower than the advertised minimums: getting about 100 Mbps down / 3.80 up with my M350 broadband, when Virgin claims 360 is expected and minimum 181).
I recently was away for a few weeks, and since coming back three days ago I notice extremely high packet loss (> 10%, sometimes 20%). I definitely didn't have this problem before, and haven't changed anything on my end.
Just set up BQM: https://www.thinkbroadband.com/broadband/monitoring/quality/share/eb4e43ed04c4e225a16fed175f6e44c83b... (the 100% drops at the very beginning are because my firewall wasn't accepting the pings yet).
I tried rebooting the hub (that's the second 100% loss spike on the graph), but it didn't help.
1 ACCEPTED SOLUTION
Accepted Solutions
Hi AurelC2G
Thanks for joining me on PM and providing me the details to confirm the tech visit for the upstream SNR issues. The visit will be viewable in your online account - virg.in/myVM - within a few hours, where you can amend/cancel if needs be.
There will be no charge for this visit unless:
• The technician diagnoses the faults as not being caused by our network/equipment
• The technician discovers that the fault or problem relates to your equipment
• The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment
Let us know how the visit goes or if you need any further help
John_GS
8 REPLIES 8
Ayisha_B
Hi @AurelC2G 👋,
A warm welcome to our Community Forums and thanks for your post. It's great to have you on board with us here 😊
I am sorry for the issues with your service. Appreciate that isn't ideal!
I have taken a look at our systems and can see there was an outage that was impacting your area. This has now been verified as resolved.
Have you noticed any improvements?
Let us know so we can offer further support if required.
Many thanks
Ayisha_B
Yes it's much better now (and clearly visible on the BQM graph I linked above), thanks!
@AurelC2G wrote:
I've been getting about 100 Mbps down / 3.80 up with my M350 broadband, when Virgin claims 360 is expected and minimum 181).
Hi @AurelC2G
Even though it's much better now you should be getting at least something close to the minimum speed on a wired connection.
Check all of your cabling, especially the white coaxial cable, and make sure it's snug and tight and free from all kinks.
There are a lot of tech guru's on the forum that can look into your issues and help, but to do that please can you post the hub stats.
Open a browser and in the address bar type in 192.168.0.1 then post the full details from the Router Status page.
Please  copy and paste 3 FULL sets of data onto here (not screenshots) – from the Downstream, Upstream, & Network Logs pages.
You should also check that the internet card in your computer set to and capable of receiving speeds higher than 100Mbps
Gig speedGig speed
Dave
The do's and don'ts.
Thanks!
Note that since the packet loss issue was fixed, upload speed is back up to where it usually sits, around 36 Mbps. Download is at about 135 Mbps (still well short of the expected speed for my M350).
These are the stats from my hub:
1178750000-0.240256 qam6
2138750000-0.238256 qam1
3146750000040256 qam2
4154750000040256 qam3
5162750000040256 qam4
6170750000040256 qam5
7186750000-0.240256 qam7
8194750000-0.440256 qam8
9202750000-0.540256 qam9
10210750000-0.740256 qam10
11218750000-140256 qam11
12226750000-140256 qam12
13234750000-140256 qam13
14242750000-1.440256 qam14
15250750000-1.540256 qam15
16258750000-1.540256 qam16
17266750000-1.540256 qam17
18274750000-1.538256 qam18
19282750000-1.738256 qam19
20290750000-1.238256 qam20
21298750000-1.540256 qam21
22306750000-1.940256 qam22
23314750000-238256 qam23
24322750000-1.740256 qam24
1Locked40.343040
2Locked38.621311
3Locked40.31990
4Locked40.35580
5Locked40.310890
6Locked40.333180
7Locked40.3420612
8Locked40.360057
9Locked40.315500
10Locked40.324260
11Locked40.321018
12Locked40.3860
13Locked40.3320
14Locked40.3190
15Locked40.31260
16Locked40.3340
17Locked40.3170
18Locked38.9160
19Locked38.9170
20Locked38.9340
21Locked40.390
22Locked40.3210
23Locked38.9160
24Locked40.3110
14960000049512064 qam1
22360000049512064 qam5
33010000049512064 qam4
43660000049512064 qam3
54310000049512064 qam2
1ATDMA0020
3ATDMA001230
4ATDMA0000
5ATDMA0010
Will post the network log in a separate message due to characters limit.
My computer's network card goes up to 2.5 Gbps, so that's not the problem. Note that I am using it in modem mode and have my own router (EdgeRouter X from Ubiquiti), but that shouldn't be the problem either as all ports are 1 Gbps.
Thanks!
02/01/2023 20:59:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 19:21:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 19:21:36criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 19:04:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 19:04:43criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 18:31:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 18:31:6criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 18:29:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 18:29:38criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 17:46:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 17:46:17criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 17:42:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 17:42:29criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 17:28:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 17:28:47criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 17:25:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 17:25:6criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 16:53:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 16:53:15criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2022 16:51:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I see a bunch of critical errors in there, but nothing since the packet loss issue was fixed, so that may be where these errors are coming from.
Hi again @AurelC2G
You should reboot the hub so you start with a fresh set of logs, then the tech guys can keep an eye on any errors that occur and see how fats theya re happening to help them pinpoint why the speed is slower than expected.
You can do that from the hub interface and Admin > Reload & Reboot > Reboot
Keep your BQM running as that will be very useful too.
Dave
Hi @AurelC2G
Thanks for coming back to the thread, you'll need a tech visit arranging, this is because on the upstream power levels, the SNR level (signal to noise ratio) is lower than expected.
I'll send you a PM now to arrange this
Best,
John_GS
Hi AurelC2G
John_GS
