  • 47
Dialled in
Message 1 of 8
Massive packet loss and T3 Timeouts today
541b3b8d5f792aea46944f6d77f0ae7133dcd51a-03-06-2020
As you can see it started at around 8:30 am and is intermittent in nature. The big spike at 12pm is me rebooting the modem.
Live graph below:
Live graphLive graph
  • 47
Dialled in
Message 2 of 8
Re: Massive packet loss and T3 Timeouts today
Downstream
 DS-1DS-2DS-3DS-4DS-5DS-6DS-7DS-8
Frequency (Hz)203000000 Hz211000000 Hz219000000 Hz227000000 Hz235000000 Hz243000000 Hz251000000 Hz259000000 Hz
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID910111213141516
ModulationQAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM256
Symbol Rate (Msym/sec)6.9526.9526.9526.9526.9526.9526.9526.952
Interleave DepthI=12I=12I=12I=12I=12I=12I=12I=12
 J=17J=17J=17J=17J=17J=17J=17J=17
Power Level (dBmV)-0.3 dBmV-1.1 dBmV-1.7 dBmV-2.6 dBmV-1.9 dBmV-2.7 dBmV-2.7 dBmV-2.6 dBmV
RxMER (dB)41.0 dB40.9 dB40.6 dB40.3 dB39.9 dB39.8 dB39.4 dB39.4 dB
  • 47
Dialled in
Message 3 of 8
Upstream
 US-1US-2US-3US-4
Channel Type2222
Channel ID2134
Frequency (Hz)53700000 Hz60300000 Hz46200000 Hz39400000 Hz
Ranging StatusSuccessSuccessSuccessSuccess
ModulationQAM64QAM32QAM32QAM64
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size64646464
Power Level (dBmV)42.0 dBmV43.3 dBmV41.3 dBmV40.3 dBmV
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts32323232
T4 Timeouts0000
  • 47
Dialled in
Message 4 of 8
First TimeLast TimePriorityError NumberDescription
 03/05/2020 11:02:18  03/05/2020 11:02:18  Warning (5)  2436694062  Unicast DSID PSN startup error
 03/05/2020 11:25:01  03/05/2020 11:25:01  Critical (3)  82000500  Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
 03/05/2020 11:00:47  03/05/2020 11:00:47  Warning (5)  2436694061  Dynamic Range Window violation
  • 47
Dialled in
Message 5 of 8
c8601069c118359db911bf2e47356d02c219d86a
  • 6.19K
  • 460
  • 1.08K
Hero
Message 6 of 8
Are your logs really a month old?
Also there appears to be something that's affecting upstream. Can you power off your hub, check that all coaxial cable connections are tight from hub to wall socket and reboot. Post some stats and logs again after a few hours.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 47
Dialled in
Message 7 of 8
The problem (red packet loss) has gone. It was only happening on that day. I suspect VM was doing maintenance work in the local area, or located and fixed the fault.
The date on the CM logs is wrong, it's counting months from 0 instead of 1.
Full day's graph for that day:
The day after:
d3f17fd9753f03ac7a4dae577294a8bab78aa864-04-06-2020
  • 4.45K
  • 261
  • 521
Message 8 of 8
Hello chris_s
Thanks for your post
Sorry to see you are still getting packet loss and Timeouts
I have had a look at a few things and can see we have an SNR issue in your area
It is due to be fixed today although that may change
You can get updates on here, just quote reference number F008124127
Gareth_L
