on 21-09-2023 21:32
Newbie here so be nice plz?
Got the 1gig package from vm and the speeds r all over the place . 1 test can show iPhone at 500mg then test again and its 80mg , that’s vpn off , vpn on (wire guard) its 45mg or slower .
Firestick 4k max on Wi-Fi only achieving 70mg no vpn and 40 with vpn, connected with Ethernet cable can get 84mg and 45 with vpn.
is there sorting I need to change with the settings ???
on 22-09-2023 08:54
It is no surprise that VPN make things slower ... you are seeing the throttled rate at the exit point.
on 22-09-2023 12:37
VPNs use a lot of processing power so its not surprising. Also your on Wifi so your speed tests arent accurate, try wired.
on 22-09-2023 18:19
AFAIK, the Amazon Firestick ethernet adapter is only 100Mb, as that's all it needs. 4K video needs around 25Mb I believe.
on 25-09-2023 08:59
Hi WGas,
Thanks for your post and welcome to the community.
Sorry to hear you've been experiencing issues with speed, may I ask are wired devices affected?
Let us know,
on 26-09-2023 15:15
