CatStan
Major Lag/Latency issues
I have hovered around the forum for a while now, but i can no longer deal with the lag that im getting. Me and my son play games like Fortnite/Rocket League/Fall Guys and many other games that require a good ping, and we are permanently getting lag, Rocket League has a permanent warning on the screen about bad latency, packet loss etc.
I have tried to resolve issues of from suggestions on here in regards to Wifi to no improvement, it is defiantly a remote problem.
I setup a BQM a while ago as was suggested, not sure what i was doing, but seemed to get a monitor up, i think this link is the result, and it looks about as bad as you'd expect.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3a44bbcb31fd8ca4eddcb0874e0e7a9fc6153e1a
Im at a stage now where i need this resolved or i need to change providers.
Could anyone be of assistance here?
conman33158
  • 1.61K
  • 133
  • 307
Super solver
Re: Major Lag/Latency issues
It's not good news I'm afraid as your line shows over utilisation.
You can ring Virgin about this with maybe a fix date for the future but to be honest I wouldn’t hold my breath as they have a tendency to apply fix dates only to keep moving them forward and then ending up with nothing being done for months/years
conman33158
  • 1.61K
  • 133
  • 307
Super solver
Can you please upload your router stats just in case there may be a fault on the line.
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
For Hubs 2 & 3 - DO NOT LOG IN, just click “Check Router Status”
For Hub 4 - When the page appears LOG IN then click on:
Advanced Settings > Tools > Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again. You can use more than one post for each item if needed.
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
CatStan
Thank you for taking the time to respond, i really appreciate it, please disregard the faults from last night, as these were likely caused by me trying everything to improve the lag
Cable Modem Status
Item Status Comments
723000000
Locked
Ranged Upstream Channel (Hz)
60299957
Locked
Provisioning State
Online
1 723000000 3 40 256 qam 40
2 539000000 1 38 256 qam 17
3 547000000 1.2 38 256 qam 18
4 555000000 1.5 38 256 qam 19
5 563000000 1.7 38 256 qam 20
6 571000000 1.5 38 256 qam 21
7 579000000 1.5 38 256 qam 22
8 587000000 1.7 38 256 qam 23
9 595000000 1.9 38 256 qam 24
10 603000000 2 38 256 qam 25
11 611000000 1.9 38 256 qam 26
12 619000000 2 38 256 qam 27
13 627000000 2.2 38 256 qam 28
14 635000000 2.4 38 256 qam 29
15 643000000 2.4 38 256 qam 30
16 651000000 2.4 38 256 qam 31
17 659000000 2.4 38 256 qam 32
18 667000000 2.7 38 256 qam 33
19 675000000 3.2 38 256 qam 34
20 683000000 3.4 38 256 qam 35
21 691000000 3.2 40 256 qam 36
22 699000000 3 40 256 qam 37
23 707000000 3.2 40 256 qam 38
24 715000000 3 38 256 qam 39
1 Locked 40.3 5 0
2 Locked 38.9 142 0
3 Locked 38.9 135 0
4 Locked 38.9 106 0
5 Locked 38.9 83 0
6 Locked 38.9 67 0
7 Locked 38.6 52 0
8 Locked 38.9 50 0
9 Locked 38.9 26 0
10 Locked 38.9 35 0
11 Locked 38.9 27 0
12 Locked 38.9 22 0
13 Locked 38.9 19 0
14 Locked 38.6 10 0
15 Locked 38.9 13 0
16 Locked 38.9 11 0
17 Locked 38.9 10 0
18 Locked 38.9 22 0
19 Locked 38.9 28 0
20 Locked 38.6 20 0
21 Locked 40.9 22 0
22 Locked 40.3 24 0
23 Locked 40.3 23 0
24 Locked 38.9 15 0
1 60299957 40 5120 64 qam 1
2 39400000 40 5120 64 qam 4
3 46200000 40 5120 64 qam 3
4 53700000 40 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
dsfd;kfoA,.iyewrkldJKDHSU
SFID 2693
Max Traffic Rate 230000061
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 2729
Max Traffic Rate 22000061
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
26/01/2021 21:47:40 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 21:46:50 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 21:39:13 notice Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 21:29:30 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 00:39:44 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 22:40:41 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 18:08:39 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 18:08:39 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 19:22:23 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 06:08:39 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 06:08:39 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 18:23:38 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 18:08:39 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 18:08:39 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 00:19:34 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 00:19:34 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 01:38:48 notice SW download Successful - Via NMS
12/01/2021 01:37:9 notice SW Download INIT - Via NMS
09/01/2021 22:00:51 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
conman33158
  • 1.61K
  • 133
  • 307
Super solver
Your router stats looks fine, it's the BQM that tells all, it boils down to over utilisation I'm afraid 😞
CatStan
I have noticed more Virgin hubs popping up over the last 12 months around where i live.
I will contact them through my account, as its mainly used for gaming and things that need a good response time, im not getting that at all currently.
Like you say, they aren't likely to fix it, as no monetary gain for them, so i may be changing providers.
Thank you for your help
