alainchateau
  • 110
  • 34
Up to speed
Message 1 of 32
M600 package, speeds very poor after being rock solid for the last 6 months.
Having issues with our m600 package the last week.
Speeds have been very poor, in particular upload speeds have taken a hit. Connection has been rock solid for the last 6 months up to now. Noticed some T3 timeouts on the router before I restarted it. Connected to Hub via Ethernet. Checked all cables etc.
Noticed bad jitter on the line when doing speed tests.
alainchateau
  • 110
  • 34
Up to speed
Message 2 of 32
Re: M600 package, speeds very poor after being rock solid for the last 6 months.
12670000000.240256 qam17
21390000001.740256 qam1
31470000001.740256 qam2
41550000001.740256 qam3
51630000001.540256 qam4
61710000001.540256 qam5
71790000001.240256 qam6
81870000001.240256 qam7
91950000001.240256 qam8
10203000000140256 qam9
112110000000.740256 qam10
122190000000.440256 qam11
132270000000.240256 qam12
142350000000.240256 qam13
152430000000.440256 qam14
162510000000.240256 qam15
172590000000.540256 qam16
182750000000.240256 qam18
19283000000140256 qam19
202910000001.540256 qam20
212990000001.740256 qam21
223070000001.540256 qam22
233150000001.740256 qam23
243230000001.740256 qam24
1Locked40.300
2Locked40.300
3Locked40.350
4Locked40.350
5Locked40.350
6Locked40.950
7Locked40.300
8Locked40.350
9Locked40.340
10Locked40.950
11Locked40.960
12Locked40.960
13Locked40.360
14Locked40.360
15Locked40.350
16Locked40.300
17Locked40.350
18Locked40.300
19Locked40.960
20Locked40.360
21Locked40.350
22Locked40.960
23Locked40.3200
24Locked40.300
12580000046.5512064 qam14
23260001247.5512064 qam13
33939998148.5512064 qam12
44619998348.5512064 qam11
3ATDMA0000
4ATDMA0000
alainchateau
  • 110
  • 34
Up to speed
Message 3 of 32
Another test just now:
alainchateau
  • 110
  • 34
Up to speed
Message 4 of 32
Some t3 timeouts now showing on channel 1 since restart.
1ATDMA0030
3ATDMA0000
4ATDMA0000
alainchateau
  • 110
  • 34
Up to speed
Message 5 of 32
T3 timeouts hit 16 overnight
alainchateau
  • 110
  • 34
Up to speed
Message 6 of 32
Lots of pre and post RS errors this morning on the downstream although speeds seem slightly better. Could it be a utilisation issue?
1Locked40.313954809
2Locked40.95661024
3Locked40.9566959
4Locked40.95781058
5Locked40.3606948
6Locked40.35949427
7Locked40.97389310
8Locked40.333810631
9Locked40.373610836
10Locked40.379510619
11Locked40.36097801
12Locked40.36108524
13Locked40.36448150
14Locked40.36038709
15Locked40.35828075
16Locked40.37428183
17Locked40.35768344
18Locked40.39428196
19Locked40.38888315
20Locked40.310278002
21Locked40.3598308
22Locked40.9518291
23Locked40.9338317
24Locked40.3208309
conman33158
  • 1.55K
  • 130
  • 294
Super solver
Message 7 of 32
Your upload power levels are bordering on the high side and you have a lot of Post RS Errors. Have you tried a factory reset? Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 10-15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection.
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Under your graph you just created Click (Share Live Graph) then click generate.
Copy the text in the “Direct Link” box and paste it on here
Eeeps
  • 817
  • 53
  • 136
Well-informed
Message 8 of 32
What are your speeds like overnight?
If you don't want to stay up and don't mind leaving your PC on then SpeedTest.net do a CLI version that can be triggered by a schedule.
alainchateau
  • 110
  • 34
Up to speed
Message 9 of 32
Hub reset.
Monitor now set-up and running here.
conman33158
  • 1.55K
  • 130
  • 294
Super solver
Message 10 of 32
We'll let your BQM run for a few hours, typically over night and see if it shows anything 🙂
