on 16-08-2021 19:36
I am on M600 Fibre Broadband yet I struggle to get over 250mbs be that wired or wireless - I used to get near 400mbs but not anything remotely close.
on 16-08-2021 19:51
15.1 ms
2.79 ms
228 Mbps
42.0 Mbps
No QOS enabled in my ASUS AC3200 Router, HUB3 in modem mode.
1 | Locked | 38.6 | 11575 | 26 |
2 | Locked | 37.3 | 8502 | 30601 |
3 | Locked | 37.3 | 6472 | 31316 |
4 | Locked | 37.3 | 7167 | 24066 |
5 | Locked | 37.3 | 13653 | 18220 |
6 | Locked | 37.3 | 26371 | 337 |
7 | Locked | 37.3 | 21599 | 62 |
8 | Locked | 37.3 | 11343 | 34 |
9 | Locked | 37.6 | 9358 | 10 |
10 | Locked | 37.6 | 20302 | 30 |
11 | Locked | 37.6 | 7345 | 13 |
12 | Locked | 38.6 | 15037 | 2007 |
13 | Locked | 38.6 | 16338 | 10696 |
14 | Locked | 37.6 | 10709 | 20211 |
15 | Locked | 38.6 | 13111 | 38 |
16 | Locked | 38.6 | 11762 | 128 |
17 | Locked | 38.6 | 15711 | 493 |
18 | Locked | 38.6 | 24427 | 1643 |
19 | Locked | 38.9 | 19823 | 12365 |
20 | Locked | 38.9 | 18761 | 14586 |
21 | Locked | 38.6 | 19530 | 13144 |
22 | Locked | 38.6 | 25194 | 4137 |
23 | Locked | 38.6 | 22061 | 217 |
24 | Locked | 38.6 | 12531 | 32 |
1 | 39400039 | 38 | 5120 | 64 qam | 4 |
2 | 46200000 | 39.5 | 5120 | 64 qam | 3 |
3 | 53699991 | 40.8 | 5120 | 64 qam | 2 |
4 | 60299986 | 40.5 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 4 | 0 |
2 | ATDMA | 0 | 0 | 5 | 2 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 16-08-2021 20:04
16-08-2021 20:11 - edited 16-08-2021 20:27
Thank you John, I have just set up BQM so will take a while, ill reboot the SH3 now.
on 17-08-2021 21:20
1 | Locked | 38.6 | 1117 | 229 |
2 | Locked | 37.6 | 1472 | 579 |
3 | Locked | 37.6 | 1525 | 498 |
4 | Locked | 37.3 | 1624 | 475 |
5 | Locked | 37.6 | 1576 | 468 |
6 | Locked | 37.3 | 1429 | 505 |
7 | Locked | 37.6 | 1304 | 464 |
8 | Locked | 37.3 | 1381 | 427 |
9 | Locked | 37.6 | 1358 | 361 |
10 | Locked | 37.6 | 1342 | 345 |
11 | Locked | 37.6 | 1326 | 321 |
12 | Locked | 38.6 | 1325 | 301 |
13 | Locked | 38.6 | 1202 | 295 |
14 | Locked | 37.6 | 1249 | 276 |
15 | Locked | 38.6 | 1290 | 267 |
16 | Locked | 37.9 | 1341 | 255 |
17 | Locked | 38.9 | 1307 | 260 |
18 | Locked | 37.6 | 1241 | 230 |
19 | Locked | 38.9 | 1118 | 259 |
20 | Locked | 38.6 | 1091 | 280 |
21 | Locked | 38.9 | 1203 | 289 |
22 | Locked | 38.6 | 1272 | 217 |
23 | Locked | 38.6 | 1240 | 226 |
24 | Locked | 38.6 | 1197 | 246 |
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3b9d5f1cbec3458f659350039586392b18e2f2a6
17-08-2021 21:42 - edited 17-08-2021 21:44
Likely the downstream being QoS for all is at utilisation and your getting as much speed as you can.
Connect a PC to the hub in modem mode run PC in safe mode with networking and do a speed test.
are you using ASUS firmware?
17-08-2021 21:46 - edited 17-08-2021 21:55
Router is in modem mode, I have an ASUS AC3200 as a router. Did that yesterday and speeds were worse, max 190mbs down.
Yes ASUS firmware not Merlin.
https://www.thinkbroadband.com/speedtest/1629233607397671655
on 19-08-2021 15:02
on 20-08-2021 23:10
No assistance no ideas or is it a case of suck it up..
on 23-08-2021 08:31
Hi @unreal2k3.
Thanks for your post 🙂
I'm very sorry to hear you're experiencing slow speeds, I appreciate how frustrating this must be and we apologise for any inconvenience caused.
If you'd like us to run some diagnostics for you to see how things are performing on our end, I advise taking your Hub out of Modem mode so we can do so.
How have things been performing since posting?
