martintsw
  • 5
Message 1 of 8
M500 with upload speed of 1-3Mb/s and 32 qam Upstream bonded channels
Since around 4:30pm today I'm getting very slow upload speed reported by Speedtest by Ookla (1-3Mb/s).
My www.thinkbroadband.com monitor shows a massive amount of packet drop since 4:30 pm today.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/393f2a3cc3b59b912b1cd208b28cb84d54...
I've done the obvious of rebooting router etc.
Hub 3.0 Router status:
1462001194.775512032 qam1
2258000004.775512032 qam4
3325999354.625512032 qam3
4393999204.775512032 qam2
3ATDMA0000
4ATDMA0000
martintsw
  • 5
Message 2 of 8
Re: M500 with upload speed of 1-3Mb/s and 32 qam Upstream bonded channels
15/09/2020 16:39:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 16:39:29criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 16:38:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 16:38:27criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 16:17:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 16:15:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:53Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:58:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:58:27criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:49:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:49:48criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:49:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:49:8criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:45:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:33:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:33:46criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:32:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:32:31criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/09/2020 15:29:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
martintsw
  • 5
Message 3 of 8
323000000
Locked
Ranged Upstream Channel (Hz)
46200119
Locked
Provisioning State
Online
martintsw
  • 5
Message 4 of 8
The upstream have gone back to 64 qam and speed is fine now (other than occasional high latency)... I'll keep an eye on it and see.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 8
Regardless of the 'fix' set up a BQM and leave it running, it won't impact on your speeds or connection in any way.
Set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub.
martintsw
  • 5
Message 6 of 8
yes... I've had it running for a year or so.
I've just ordered the 1 gig / Gig1 service, so let's see if throwing more money at it and a new router helps 🙂
Andrew-G
  • 6.11K
  • 1.07K
  • 2.58K
Message 7 of 8
Hmmm.  You've read the posts in this forum about the Hub 4 and Gig 1 ?
Aaron2
  • 866
  • 97
  • 161
Well-informed
Message 8 of 8
In modem mode it's quite solid, from my usage anyway.
** I work for VirginMedia but all opinions posted here are my own.
