bdias
  • 10
Message 1 of 17
M500 very slow, less than 100mb
Hi - I have the M500 broadband package, and noticed that my download speed is very slow. When I ran a speed test when connected via network cable direct to my Hub 3, top speed I am getting is 100mb, but it can vary between 30 and 100. Tried calling VM, but last stage I got to was they will send me a link to report the fault via a text, which I never received. I have done a factory reset a week ago, that has not resolved the issue.
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 17
Re: M500 very slow, less than 100mb
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
bdias
  • 10
Message 3 of 17
Thanks Mike, speed for the connected device is 100 mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 17
OK.
That points to either an iffy ethernet cable
or
The device Network Interface Card (NIC) is either old and maxed out or set wrong .
Simplest test is to use another Cat 5E / 6 cable.
bdias
  • 10
Message 5 of 17
Ok, previous test was on an old laptop. Changed to a newer laptop and checked the Connected Devices page on my hub, speed for this device is shown as 1000 mbps. Ran https://www.speedtest.net, and got 139 mbps first time, second time got 100mbps, which is still poor when I am contracted to M500.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 17
Have you got another cable to try with ?
bdias
  • 10
Message 7 of 17
Changed from old cat5 to new cat8 cable, now getting 320mbps download speed.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 17
We seem to be getting somewhere.
Now for the copying and pasting ...
Then
Can you please
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
bdias
  • 10
Message 9 of 17
My BQM
bdias
  • 10
Message 10 of 17
Downstream Tab:
13310000005.438256 qam25
22350000001.937256 qam13
32430000001.737256 qam14
42510000002.237256 qam15
5259000000338256 qam16
62670000003.738256 qam17
72750000003.738256 qam18
82830000003.538256 qam19
92910000003.738256 qam20
102990000004.438256 qam21
113070000004.638256 qam22
123150000004.938256 qam23
133230000005.338256 qam24
143390000005.638256 qam26
153470000005.538256 qam27
163550000005.438256 qam28
17363000000538256 qam29
183710000004.838256 qam30
19379000000538256 qam31
203870000005.538256 qam32
21395000000640256 qam33
224030000005.840256 qam34
234110000005.838256 qam35
244190000005.538256 qam36
1Locked38.6127305
2Locked37.6141290
3Locked37.6147308
4Locked37.6149600
5Locked38.6128799
6Locked38.9139520
7Locked38.6145339
8Locked38.691274
9Locked38.97778
10Locked38.673103
11Locked38.9101288
12Locked38.9105487
13Locked38.9112493
14Locked38.9101308
15Locked38.956112
16Locked38.948187
17Locked38.95374
18Locked38.953150
19Locked38.974286
20Locked38.6108311
21Locked40.3134303
22Locked40.991263
23Locked38.968171
24Locked38.948114
