Spondodge
  • 14
Message 1 of 1
M500 speed significant slowdown and latency - North West
I have significantly slower downstream speeds and latency spikes since 19th December.  I have consistantly high speeds normally 450mbit+
Please investigate.
Troubleshooting completed
  • Restored Superhub 3 to factory defaults
  • Allowed hub to restore itself and connect with no ethernet cables connected
  • Pressed pin hole reset button to restart
  • Checked all cables are tight and connected into SuperHub correctly.
  • Restarted several times
  • Tested Different Ethernet ports
  • Tested WiFi speedtest
  • Tried several different speedtest websites
Superhub 3 Router Status
Channel	Frequency (Hz)	Power (dBmV)	SNR (dB)	Modulation	Channel ID
1	330750000	6	38	256 qam	25
2	250750000	4.6	38	256 qam	15
3	258750000	5	37	256 qam	16
4	266750000	5.5	38	256 qam	17
5	274750000	5.3	38	256 qam	18
6	282750000	5.3	38	256 qam	19
7	290750000	5.4	37	256 qam	20
8	298750000	6	38	256 qam	21
9	306750000	6	38	256 qam	22
10	314750000	5.8	38	256 qam	23
11	322750000	5.6	37	256 qam	24
12	370750000	5.6	38	256 qam	26
13	378750000	5.9	38	256 qam	27
14	386750000	5.6	38	256 qam	28
15	394750000	5.3	38	256 qam	29
16	402750000	5	38	256 qam	30
17	410750000	5	38	256 qam	31
18	418750000	5	38	256 qam	32
19	426750000	4.9	38	256 qam	33
20	434750000	4.5	38	256 qam	34
21	442750000	4	38	256 qam	35
22	450750000	4.1	38	256 qam	36
23	458750000	4.1	38	256 qam	37
24	466750000	4	37	256 qam	38
Channel	Locked Status	RxMER (dB)	Pre RS Errors	Post RS Errors
1	Locked	38.6	8	0
2	Locked	38.6	11	0
3	Locked	37.3	13	0
4	Locked	38.6	6	0
5	Locked	38.6	13	0
6	Locked	38.9	11	0
7	Locked	37.6	12	0
8	Locked	38.9	19	0
9	Locked	38.9	24	0
10	Locked	38.6	21	0
11	Locked	37.3	7	0
12	Locked	38.6	7	0
13	Locked	38.6	12	0
14	Locked	38.9	24	0
15	Locked	38.9	11	0
16	Locked	38.6	17	0
17	Locked	38.6	18	0
18	Locked	38.9	9	0
19	Locked	38.9	34	0
20	Locked	38.6	25	0
21	Locked	38.6	9	0
22	Locked	38.6	9	0
23	Locked	38.6	9	0
24	Locked	37.6	14	0
Channel	Frequency (Hz)	Power (dBmV)	Symbol Rate (ksps)	Modulation	Channel ID
1	39400000	43.5	5120	64 qam	2
2	32600000	43	5120	64 qam	3
3	46199903	43.8	5120	32 qam	1
4	53700000	44	5120	64 qam	4
Channel	Channel Type	T1 Timeouts	T2 Timeouts	T3 Timeouts	T4 Timeouts
1	ATDMA	0	0	0	0
2	ATDMA	0	0	0	0
3	ATDMA	0	0	0	0
4	ATDMA	0	0	0	0
Time	Priority	Description
25/12/2020 19:58:14	notice	LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 23:54:37	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 12:03:34	notice	LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 08:52:32	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 02:09:52	notice	LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 12:42:22	Warning!	Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 12:42:19	Warning!	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 12:42:19	critical	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 12:42:18	Warning!	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 12:42:18	critical	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 18:29:45	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 20:37:30	notice	LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:41	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 19:48:34	notice	LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 19:46:55	notice	NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 19:22:47	notice	LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:36	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 19:13:50	notice	LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 18:29:36	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Speedtest / Broadband Quality Monitor
https://www.speedtest.net/results?sh=13c1d6931395d98c8dc942da0718d27f
ThinkBroadband Quality Monitor:
My Broadband Ping - Virgin Broadband Connection
