on 27-04-2022 13:32
I switched from M350 to M500 a month or so ago and since my speeds have never reached the 500Mbps level and I'm seeing lag in the evenings on my BQM's, on M350 I always got more than 360Mbps.
I always use a wired connection.
Can someone please explain why I'm not getting what I'm paying for?
Acquired Downstream Channel (Hz) | 386750000 | Locked |
Ranged Upstream Channel (Hz) | 53699991 | Locked |
Provisioning State | Online |
1 | 386750000 | 1 | 40 | 256 qam | 32 |
2 | 202750000 | 0.2 | 38 | 256 qam | 9 |
3 | 210750000 | 0.4 | 38 | 256 qam | 10 |
4 | 218750000 | 0.2 | 40 | 256 qam | 11 |
5 | 226750000 | 0.4 | 40 | 256 qam | 12 |
6 | 234750000 | 0 | 38 | 256 qam | 13 |
7 | 242750000 | -0.2 | 38 | 256 qam | 14 |
8 | 250750000 | 0 | 38 | 256 qam | 15 |
9 | 258750000 | 0.2 | 38 | 256 qam | 16 |
10 | 266750000 | 0.4 | 38 | 256 qam | 17 |
11 | 274750000 | 0.4 | 38 | 256 qam | 18 |
12 | 282750000 | 0.7 | 40 | 256 qam | 19 |
13 | 290750000 | 0.7 | 40 | 256 qam | 20 |
14 | 298750000 | 0.7 | 40 | 256 qam | 21 |
15 | 306750000 | 0.7 | 40 | 256 qam | 22 |
16 | 314750000 | 0.9 | 40 | 256 qam | 23 |
17 | 322750000 | 0.5 | 38 | 256 qam | 24 |
18 | 330750000 | 0.7 | 40 | 256 qam | 25 |
19 | 338750000 | 1 | 38 | 256 qam | 26 |
20 | 346750000 | 1 | 40 | 256 qam | 27 |
21 | 354750000 | 0.9 | 40 | 256 qam | 28 |
22 | 362750000 | 1 | 40 | 256 qam | 29 |
23 | 370750000 | 1.4 | 40 | 256 qam | 30 |
24 | 378750000 | 1.2 | 40 | 256 qam | 31 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 02-05-2022 17:12
Can't you check power levels when the hub 3 is in modem mode as I need the wifi and the Hub 3 is useless at wifi?
on 02-05-2022 17:16
1 | 386750000 | 0.9 | 40 | 256 qam | 32 |
5 | 226750000 | 0.2 | 40 | 256 qam | 12 |
10 | 266750000 | 0.2 | 38 | 256 qam | 17 |
11 | 274750000 | 0.2 | 38 | 256 qam | 18 |
12 | 282750000 | 0.5 | 40 | 256 qam | 19 |
14 | 298750000 | 0.5 | 40 | 256 qam | 21 |
16 | 314750000 | 0.7 | 40 | 256 qam | 23 |
18 | 330750000 | 0.5 | 40 | 256 qam | 25 |
19 | 338750000 | 1 | 40 | 256 qam | 26 |
20 | 346750000 | 0.9 | 40 | 256 qam | 27 |
21 | 354750000 | 0.7 | 40 | 256 qam | 28 |
23 | 370750000 | 1.2 | 40 | 256 qam | 30 |
24 | 378750000 | 1 | 40 | 256 qam | 31 |
1 | 53699961 | 46.5 | 5120 | 64 qam | 10 |
2 | 39400014 | 46.5 | 5120 | 64 qam | 12 |
3 | 46200000 | 46.5 | 5120 | 64 qam | 11 |
4 | 60299998 | 48 | 5120 | 64 qam | 9 |
on 05-05-2022 11:50
Hi Nightgaunt
Thanks for your post
Sorry to hear about the issue with your connection
I have had a look from here and all the levels are okay
Which means we will need to get a Technician out
If you don't mind, I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
