Nightgaunt
  • 27
  • 5
Message 1 of 13
M500 speed not giving full speed
I switched from M350 to M500 a month or so ago and since my speeds have never reached the 500Mbps level and I'm seeing lag in the evenings on my BQM's, on M350 I always got more than 360Mbps.
I always use a wired connection.
Can someone please explain why I'm not getting what I'm paying for?
386750000
Locked
Ranged Upstream Channel (Hz)
53699991
Locked
Provisioning State
Online
1386750000140256 qam32
22027500000.238256 qam9
32107500000.438256 qam10
42187500000.240256 qam11
52267500000.440256 qam12
6234750000038256 qam13
7242750000-0.238256 qam14
8250750000038256 qam15
92587500000.238256 qam16
102667500000.438256 qam17
112747500000.438256 qam18
122827500000.740256 qam19
132907500000.740256 qam20
142987500000.740256 qam21
153067500000.740256 qam22
163147500000.940256 qam23
173227500000.538256 qam24
183307500000.740256 qam25
19338750000138256 qam26
20346750000140256 qam27
213547500000.940256 qam28
22362750000140256 qam29
233707500001.440256 qam30
243787500001.240256 qam31
2ATDMA0010
3ATDMA0010
4ATDMA0010
  • 35.1K
  • 3.41K
  • 6.68K
Message 2 of 13
Re: M500 speed not giving full speed
Do a pinhole reset first first make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. Passwords will reset to those on the sticker. See if that sorts it.
If not, then check in the settings for the "configuration file" - look in the up/down boxes for "Max Data Rate Transfer".
If the upgrade was successful the numbers in there will start 6xxxxx.... (in bps - not Mbps) if it hasn't they will start 4xxxx..... and you would need to call in and ask why not.
The evening lag on the BQM is being shown on every customers BQM - they dont seem to be doing much to sort it though
Nightgaunt
  • 27
  • 5
Message 3 of 13
Thanks for the response, this is from the config tab after a reset:
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
A,.iyewrkldJKDHSUBsgvca69
SFID9780
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID9777
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
  • 35.1K
  • 3.41K
  • 6.68K
Message 4 of 13
Yep thats the 500 service (I hit 6 rather than 5 🙂 )
Are the speeds still slow? If so can you test it like this....
___________________________________________
Connect a 1GB enabled computer/laptop, with up to date drivers, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub which you have put into “modem mode” (https://www.virginmedia.com/help/virgin-media-hub-modem-mode ).
This ensures that NO other devices are connected
Test speeds at https://speedtest.samknows.com/ - try on 2 different browsers.
If they are still low – boot your device into Windows safe+networking mode - to disable any potentially interfering software - and try again.
There are many posts on here (I have a list of ~30!) where QoS software, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
Nightgaunt
  • 27
  • 5
Message 5 of 13
My main PC has a Z690 motherboard with a 2.5Gb network card, 32Gb of DDR5 and an i9-12900K cpu with all the latest drivers.
I've already switched out CAT 6 cables and tried in safe mode, I only use the Hub in modem mode as I have my own router for wireless as the Hub 3 is useless but still get an average of 350-400Mbps depending upon time of day.
Ironically even wireless shows the same speeds
  • 35.1K
  • 3.41K
  • 6.68K
Message 6 of 13
What make/model of router are you using?
Is there any QoS running on it that you may not be aware of? A number of similar issues reported on here recently, were a result of that.
Nightgaunt
  • 27
  • 5
Message 7 of 13
It's a TP Link AC5400
Nightgaunt
  • 27
  • 5
Message 8 of 13
Forgot to add I've tried with QoS for gaming and with it switch off too, no difference
carl_pearce
  • 1.76K
  • 114
  • 378
Super solver
Message 9 of 13
What does your upstream data look like?
Paulina_Z
  • 5.09K
  • 190
  • 397
Message 10 of 13
Hi @Nightgaunt,
Welcome back to our Community Forums! Thank you for your post and I'm very sorry to hear that you're experiencing some speed issues! I understand how frustrating that can be, especially after your recently speed upgrade.
I can see that you've stated that you use the Virgin Media Hub in Modem Mode as you use a third party router as a main source of WiFi. Unfortunately, we cannot support third party routers and can only run thorough checks on our own equipment. If you'd like, we would be able to run further checks on your power levels if you temporarily switch back to Router Mode on your Virgin Media Hub for at least 24 hours. This way, we'll be able to run checks on our equipment to ensure that it is not the Hub that is causing you the speed issues. If it is the VM Hub that is causing problems, we'll be able to arrange for a technician appointment to investigate this further.
Please keep us updated on how you'd like to proceed, so we can help.
Thank you.
Paulina_Z
