adailquazi
  • 8
Message 1 of 14
M500 speed not as advertised
Hi All
I have been consistently testing my speed through Ethernet and Wi-Fi throughout the day, daily. I am only getting max speeds of about 250mb, typically around 200mb.
It stubbornly refuses to go beyond that.  The expectation is around 400mb plus but I don't get that.
I am on the full whack oomph bundle.  BT have recently installed FTTP 1 gig fibre optic on my road so that is very tempting given my contract is ending soon, however, I would be OK if I get somewhere close to 500 🙂
I called Virgin and was told that it depends on others using the network on my road at the same time??
Any advice would be appreciated - I have done the usual stuff like rebooting, etc.
Anonymous
Not applicable
Message 2 of 14
Re: M500 speed not as advertised
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
adailquazi
  • 8
Message 3 of 14
12587500003.238256 qam16
22507500003.438256 qam15
32667500003.438256 qam17
42747500003.238256 qam18
52827500003.538256 qam19
62907500003.938256 qam20
7298750000438256 qam21
83067500003.738256 qam22
93147500003.738256 qam23
103227500003.938256 qam24
113307500003.238256 qam25
123787500003.738256 qam26
133867500003.238256 qam27
14394750000338256 qam28
154027500003.438256 qam29
164107500003.538256 qam30
174187500003.238256 qam31
184267500003.738256 qam32
194347500004.138256 qam33
204427500003.938256 qam34
214507500003.738256 qam35
22458750000438256 qam36
234667500003.738256 qam37
244747500003.538256 qam38
1Locked38.91440
2Locked38.61320
3Locked38.61410
4Locked38.91380
5Locked38.61520
6Locked38.91180
7Locked38.61100
8Locked38.61410
9Locked38.61480
10Locked38.61350
11Locked38.91950
12Locked38.9980
13Locked38.91360
14Locked38.91680
15Locked38.91210
16Locked38.91310
17Locked38.91270
18Locked38.91340
19Locked38.6700
20Locked38.9950
21Locked38.9850
22Locked38.9920
23Locked38.9820
24Locked38.6860
adailquazi
  • 8
Message 4 of 14
13940000048512064 qam6
22580005948.8512032 qam8
34620001948.3512064 qam5
43260000047.8512064 qam7
2ATDMA0010
3ATDMA0000
4ATDMA0010
adailquazi
  • 8
Message 5 of 14
24/09/2020 21:41:41Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/09/2020 23:49:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 17:45:26ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 17:27:7ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 16:20:8ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 16:08:51ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 15:27:38ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 15:16:20ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 14:35:7ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 14:23:50ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 13:42:37ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 13:31:20ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 12:50:7ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 12:38:49ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/09/2020 14:46:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 21:32:0ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 21:13:41ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 20:06:42ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 19:55:25ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 19:14:11ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
adailquazi
  • 8
Message 6 of 14
Anonymous
Not applicable
Message 7 of 14
Your BQM isn't working.
It appears one of your upstream channels is out of spec:
Power levels high but in spec.
adailquazi
  • 8
Message 8 of 14
Thanks, any way of solving the out of spec issue please?
Not sure what's hapening with BQM - packets are just getting dropped
Anonymous
Not applicable
Message 9 of 14
You need an engineer visit.
The BQM is not working at all. It's probably being blocked by your HUB.
  • 23.96K
  • 2.54K
  • 4.35K
Message 10 of 14
Two reasons likely for the red wall.
Your i.p. address may have changed since you set it up - this happened to me a week or so ago. Check your i.p. and if it has changed - put the new one into the BQM settings.
Or as Carl says - the Hub may not be accepting pings. So navigate to the Hub web interface
and somewhere in Advanced Settings > Advanced > Ping > there should be a box to tick to "allow/respond to ICMP echo requests sent to WAN IP (or similar)
