NJT1875
  • 6
Message 1 of 10
M500 slower after upgrade
Hello.  First post so excuse me not posting anything I should for people to help.  I have upgraded from 350 to 500 and noticed a drop in speed.  Currently hitting 52down 32up, which obvioulsy is disappointing.  I have posted what I have seen others post, any ideas?  nic.
13870000005.840256 qam32
2203000000540256 qam9
3211000000540256 qam10
42190000005.140256 qam11
52270000005.140256 qam12
6235000000540256 qam13
7243000000540256 qam14
8251000000540256 qam15
92590000005.140256 qam16
10267000000540256 qam17
11275000000540256 qam18
12283000000540256 qam19
13291000000540256 qam20
14299000000540256 qam21
15307000000540256 qam22
16315000000540256 qam23
173230000005.340256 qam24
183310000005.540256 qam25
193390000005.540256 qam26
203470000005.640256 qam27
213550000005.540256 qam28
223630000005.640256 qam29
233710000005.640256 qam30
243790000005.940256 qam31
1Locked40.910
2Locked40.960
3Locked40.940
4Locked40.960
5Locked40.360
6Locked40.960
7Locked40.950
8Locked40.950
9Locked40.960
10Locked40.360
11Locked40.340
12Locked40.970
13Locked40.370
14Locked40.370
15Locked40.960
16Locked40.370
17Locked40.980
18Locked40.960
19Locked40.970
20Locked40.380
21Locked40.990
22Locked40.370
23Locked40.380
24Locked40.310
0
Network LogTime Priority Description
01/01/1970 01:30:8ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:27:50noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:36ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:20noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:00:10ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:48Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/11/2020 14:50:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2020 18:41:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2020 08:13:58ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 08:50:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 20:13:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 13:52:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 13:15:3ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 18:32:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 13:42:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:24:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:42:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 14:03:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:42:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 02:30:54critical
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 10
Re: M500 slower after upgrade
Can you post the Upstream & Configuration data as well please.
NJT1875
  • 6
Message 3 of 10
Hi mike.  Sure, as below:
16030000036.8512064 qam6
24620000037512064 qam8
35370000037512064 qam7
43940000037512064 qam9
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053+voc-b.cm
SFID26344
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID26343
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Thank you
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 10
NJT1875
  • 6
Message 5 of 10
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 10
Your BQM is showing all red, that is normally an indication that the Hub isn't responding to pings.
Can you log in to your Hub and set the Hub Firewall up as shown below.
Hub-3-Firewall
NJT1875
  • 6
Message 7 of 10
hi Mike.
I dont even have that option
NJT1875
  • 6
Message 8 of 10
Hi Mike.  I am running in Modem mode, connected to aZyXEL Multy X Tri-Band AC3000 Whole Home Wi-Fi Mesh System.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 10
You need to enable ICMP on your ZyXEL Router.
NJT1875
  • 6
Message 10 of 10
Morning Mike.  ZyXEL block that feature on the Multy X - in fact they are fairly inflexible and I think half the probelm may lie there.  I am considering swaping to something else that will just give me strong wifi coverage and 2/3 wired points.  Any suggestions?  Oh and thanks for giving up time to help me, much appreciated.  nic.
