I've been on the M500 package for a few months and have yet to see consistent speeds that I'd expect.
I've tested wired and wireless using the Hub3 as is and also in modem mode with a netgear R7800. I struggle to get about 300mbps downstream most of the time, occasionally it does go higher but not very often. Oddly the downstream is rock steady at 36-37 mbps. After reading others posts here it seems I may have an issue, can a member of the forum team pick this up and take a look at my stats for me please. Pasted below a short time after a reboot of the hub.
Item Status Comments
Acquired Downstream Channel (Hz) | 371000000 | Locked |
Ranged Upstream Channel (Hz) | 60299998 | Locked |
Provisioning State | Online |
1 | 371000000 | 13.8 | 40 | 256 qam | 26 |
2 | 195000000 | 14 | 40 | 256 qam | 8 |
3 | 203000000 | 14 | 40 | 256 qam | 9 |
4 | 211000000 | 13.8 | 38 | 256 qam | 10 |
5 | 219000000 | 13.6 | 40 | 256 qam | 11 |
6 | 227000000 | 13.5 | 40 | 256 qam | 12 |
7 | 235000000 | 13.4 | 38 | 256 qam | 13 |
8 | 243000000 | 13.5 | 38 | 256 qam | 14 |
9 | 251000000 | 13.6 | 40 | 256 qam | 15 |
10 | 259000000 | 13.5 | 40 | 256 qam | 16 |
11 | 267000000 | 13.5 | 40 | 256 qam | 17 |
12 | 275000000 | 13.4 | 40 | 256 qam | 18 |
13 | 283000000 | 13.5 | 40 | 256 qam | 19 |
14 | 291000000 | 13.5 | 38 | 256 qam | 20 |
15 | 299000000 | 13.5 | 38 | 256 qam | 21 |
16 | 307000000 | 13.5 | 38 | 256 qam | 22 |
17 | 315000000 | 13.8 | 38 | 256 qam | 23 |
18 | 323000000 | 13.6 | 38 | 256 qam | 24 |
19 | 363000000 | 13.8 | 40 | 256 qam | 25 |
20 | 379000000 | 14 | 40 | 256 qam | 27 |
21 | 387000000 | 14 | 40 | 256 qam | 28 |
22 | 395000000 | 14 | 40 | 256 qam | 29 |
23 | 403000000 | 13.6 | 38 | 256 qam | 30 |
24 | 411000000 | 13.5 | 38 | 256 qam | 31 |
1 | Locked | 40.3 | 5 | 0 |
2 | Locked | 40.3 | 4 | 0 |
3 | Locked | 40.3 | 5 | 0 |
4 | Locked | 38.9 | 5 | 0 |
5 | Locked | 40.3 | 6 | 0 |
6 | Locked | 40.3 | 5 | 0 |
7 | Locked | 38.9 | 0 | 0 |
8 | Locked | 38.9 | 4 | 0 |
9 | Locked | 40.3 | 5 | 0 |
10 | Locked | 40.3 | 0 | 0 |
11 | Locked | 40.3 | 5 | 0 |
12 | Locked | 40.3 | 5 | 0 |
13 | Locked | 40.3 | 4 | 0 |
14 | Locked | 38.9 | 6 | 0 |
15 | Locked | 38.9 | 5 | 0 |
16 | Locked | 38.9 | 5 | 0 |
17 | Locked | 38.9 | 5 | 0 |
18 | Locked | 38.9 | 5 | 0 |
19 | Locked | 40.3 | 0 | 0 |
20 | Locked | 40.9 | 5 | 0 |
21 | Locked | 40.3 | 4 | 0 |
22 | Locked | 40.3 | 5 | 0 |
23 | Locked | 38.9 | 7 | 0 |
24 | Locked | 38.9 | 0 | 0 |
