karavadra24
M500 slow speed - 60Mbps
I ordered the M500 package, upgrading from the M100. I received the new Hub 3 and plugged it in. However, my download speed hasn't changed at all. According to Virgin's speed table (https://www.virginmedia.com/shop/broadband/speeds), it should be minimum 258 Mbps, but it stays the same as M100, goes max to 65 Mbps. I have tried to contact virgin media through telephone, however my phone keeps getting cut off. I am guessing this is due to coronavirus and the lines being busy, but I have no one to ask for help regarding this issue. I hope someone can help me out.
Thank you!
Tags (3)
Eeeps
  • 726
  • 46
  • 117
Rising star
Re: M500 slow speed - 60Mbps
The usual questions about this and requests for more information.
How are you measuring the speed (wired/wireless), what speed test site and on what device?
If wireless, which wireless band are you connected on?
More information.
Connect to you SH3 using a web browser.
Connect to the status pages and copy and post the results here.
karavadra24
Thanks for the reply. I am using an ethernet connection, testing the speed on speedtest by Ookla website, on a PC.
Device name MAC address IP address Speed (Mbps) Connected to
DESKTOP-7FG3LFE **:**:**:**:**:** 192.168.0.12/24 100 Ethernet.
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
@karavadra24 wrote:
That device is only connecting at 100Mbps, so you won't see more than 80 - 90Mbps real world.
You need to check if your device has a gigabit ethernet adapter and try a different network cable.
karavadra24
Ive just check the cable and its a cat5 cable. Sorry for the inconvenience. Ill get that changed asap.
Thank you for your help!!
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
@karavadra24 wrote:
You're welcome. Cat 5e or higher, unless you already knew.
