deanym
  • 10
Message 1 of 16
M500 package but only 250 speed
Upgraded my broadband to m500 just before Christmas, but have never seen above 250 wired or wireless.
I have a hub 3, do I need a hub 4 or does virgin need to to action something?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 16
Re: M500 package but only 250 speed
Hub 3 is perfectly adequate for 500Mbs.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 16
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
deanym
  • 10
Message 4 of 16
Hi Mike, thanks for the hints, see the my BQM below.
My BQM2
The router info you suggested is added in the replies below this.
Really appreciated this, thank you.
deanym
  • 10
Message 5 of 16
Downstream,
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
299000000
5.8
40
256 qam
21
2
203000000
4.4
40
256 qam
9
3
211000000
4.6
38
256 qam
10
4
219000000
5
40
256 qam
11
5
227000000
5.3
40
256 qam
12
6
235000000
5.5
40
256 qam
13
7
243000000
5.6
40
256 qam
14
8
251000000
5.8
40
256 qam
15
9
259000000
5.6
40
256 qam
16
10
267000000
5.5
40
256 qam
17
11
275000000
5.5
40
256 qam
18
12
283000000
5.5
40
256 qam
19
13
291000000
5.8
40
256 qam
20
14
307000000
5.6
40
256 qam
22
15
315000000
5.6
40
256 qam
23
16
323000000
5.6
40
256 qam
24
17
331000000
5.6
40
256 qam
25
18
371000000
6.4
40
256 qam
26
19
379000000
6.5
40
256 qam
27
20
387000000
6.5
40
256 qam
28
21
395000000
6.5
40
256 qam
29
22
403000000
6.8
40
256 qam
30
23
411000000
7
40
256 qam
31
24
419000000
7.1
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
50
0
2
Locked
40.3
25
0
3
Locked
38.9
45
0
4
Locked
40.3
4
0
5
Locked
40.3
16
0
6
Locked
40.3
10
0
7
Locked
40.3
12
0
8
Locked
40.9
15
0
9
Locked
40.3
16
0
10
Locked
40.3
13
0
11
Locked
40.3
12
0
12
Locked
40.9
18
0
13
Locked
40.3
12
0
14
Locked
40.9
45
0
15
Locked
40.3
53
0
16
Locked
40.9
26
0
17
Locked
40.9
13
0
18
Locked
40.3
3
0
19
Locked
40.9
12
0
20
Locked
40.3
20
0
21
Locked
40.9
12
0
22
Locked
40.3
14
0
23
Locked
40.3
14
0
24
Locked
40.9
18
0
deanym
  • 10
Message 6 of 16
Upstream,
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
47.8
5120
64 qam
5
2
53700000
48.5
5120
64 qam
2
3
39400000
47.3
5120
64 qam
4
4
46200000
47.5
5120
64 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
1
0
deanym
  • 10
Message 7 of 16
Configuration
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID
531824
Max Traffic Rate
575000000
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
531823
Max Traffic Rate
38520000
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
deanym
  • 10
Message 8 of 16
me
Priority
Description
06/01/2021 05:38:49
critical
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 05:36:10
notice
SW download Successful - Via NMS
06/01/2021 05:34:16
notice
SW Download INIT - Via NMS
06/01/2021 02:28:26
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 13:27:56
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 11:11:18
critical
05/01/2021 06:03:8
Warning!
05/01/2021 06:03:8
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 06:03:8
Warning!
05/01/2021 06:03:8
Warning!
04/01/2021 09:13:4
Warning!
04/01/2021 09:12:52
critical
03/01/2021 14:15:32
Warning!
02/01/2021 01:27:56
Error
29/12/2020 20:33:33
critical
29/12/2020 13:27:56
Error
27/12/2020 19:20:44
critical
26/12/2020 09:04:43
Error
24/12/2020 01:05:14
critical
22/12/2020 16:26:12
Warning!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 16
My BQM2
Your BQM is showing all red, this is possibly because the Hub is not responding to pink.
Can you log in to the Hub settings and set the Hub firewall as shown below please ..
Hub-3-Firewall
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 16
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
