JillC
Message 1 of 10
M500 no signal upstairs
We had phone, TV and M500 installed yesterday. While my phone is getting 200+ on spedtest(which is still nowhere near correct), I've got 2 Ps4's upstairs and they can't even get 30Mbps and most of the time, can't even connect due to the signal being so poor.
Its a 1995 build house so it's not even big. 3 bedrooms.
Just moved from BT and I think it was the worst mistake I made.
Do I move back before my 24 days cooling period is up or stick it out and get it sorted with Boosters (that aren't even available until the end of January)..?
Any advice?
  • 15.44K
  • 662
  • 1.51K
Message 2 of 10
Re: M500 no signal upstairs
Faster to get your own wireless router with 1Gb ports and use the hub in modem mode.
I would guess your wired speed to the hub is fine?
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 3 of 10
Any advice?
Why do you say that?
JillC
Message 4 of 10
Why do I say what?
  • 15.44K
  • 662
  • 1.51K
Message 5 of 10
Because people think like that "Oooo 500Mb by wifi"😑.
conman33158
  • 734
  • 66
  • 95
Superfast
Message 6 of 10
You only have 14 days cooling of period, NOT 24 days.
JillC
Message 7 of 10
I know, sorry... Phone decided to put 24.. 🤦🏻‍♀️
conman33158
  • 734
  • 66
  • 95
Superfast
Message 8 of 10
You would probably be better off with a mesh system or a third party router and put the hub in modem mode. This would give you better coverage all round 🙂
-tony-
  • 15.99K
  • 1.26K
  • 3.77K
Message 9 of 10
its 14 day cooling off - split the wifi bands and turn off smart wifi - you can then connect to the band of your choice - that should held but the wifi on the hub is poor - ok it works for some
boosters are now pods and they are going to cost you £5 a month for ever unless you are on the ultimate oomph or whatever its called
far better to look at other solutions - cost you up front but its yours - you may even be able to use the BT hub if you have still got it - not as a modem but the wifi on it should work if set up correctly
as to games machines wifi is never a good solution - you should look at lan connections
____________________
Tony
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 10 of 10
@JillC wrote:
Why do I say what?
What I highlighted.
