mutts21
  • 5
M500 download same speed as M200
Hello, I have recently changed to M500, the upload speed is fine but the download speed is at best the same as M200 and often slower than it was.  Resets and reboots have been done, lan or WiFi makes no difference, connections undone and re-tightened, all the same on MacBook, iPad, windows and android.
I have included the logs, if anyone could give me some idea of what the problem is I would be very grateful.
Thank you in advance.
Refresh data
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID 79386
Max Traffic Rate 575000000
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 79385
Max Traffic Rate 38520000
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
Refresh data
1 203000000 7.1 38 256 qam 9
2 211000000 7.3 38 256 qam 10
3 219000000 6.8 40 256 qam 11
4 227000000 7 40 256 qam 12
5 235000000 6.8 40 256 qam 13
6 243000000 6.1 40 256 qam 14
7 251000000 6.4 40 256 qam 15
8 259000000 6.5 40 256 qam 16
9 267000000 6.3 40 256 qam 17
10 275000000 6.4 40 256 qam 18
11 283000000 5.8 40 256 qam 19
12 291000000 6 40 256 qam 20
13 299000000 6.5 40 256 qam 21
14 307000000 6.9 40 256 qam 22
15 315000000 6.3 40 256 qam 23
16 323000000 6.6 40 256 qam 24
17 331000000 6.4 38 256 qam 25
18 339000000 6.9 38 256 qam 26
19 347000000 7 40 256 qam 27
20 355000000 6 38 256 qam 28
21 363000000 6.4 38 256 qam 29
22 371000000 6 38 256 qam 30
23 379000000 6.5 38 256 qam 31
24 387000000 6.3 38 256 qam 32
1 Locked 38.6 3232 1769
2 Locked 38.9 2346 1065
3 Locked 40.3 2959 1810
4 Locked 40.3 3076 2085
5 Locked 40.9 2979 1993
6 Locked 40.3 2954 1923
7 Locked 40.3 1745 8192
8 Locked 40.3 1687 8295
9 Locked 40.3 1632 8368
10 Locked 40.3 1690 8309
11 Locked 40.3 1642 8404
12 Locked 40.3 1811 8074
13 Locked 40.3 2625 7820
14 Locked 40.3 2011 8602
15 Locked 40.3 859 9699
16 Locked 40.3 1043 9777
17 Locked 38.9 850 10050
18 Locked 38.9 1116 5657
19 Locked 40.3 1070 6396
20 Locked 38.9 441 8160
21 Locked 38.6 644 8085
22 Locked 38.6 405 9234
23 Locked 38.9 516 7695
24 Locked 38.9 251 974
Refresh data
1 60300000 40 5120 64 qam 1
2 46200000 39.3 5120 64 qam 3
3 53700000 39.8 5120 64 qam 2
4 39400000 38.8 5120 64 qam 4
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Refresh data
30/01/2021 10:43:27 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 10:38:0 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 10:37:56 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 10:37:56 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 10:37:54 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 10:35:52 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 10:35:47 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 10:35:47 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 10:35:46 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 10:35:46 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 08:57:11 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 08:56:56 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 19:17:55 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 20:08:2 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 04:05:42 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 17:05:23 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 16:05:42 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2021 14:49:3 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Re: M500 download same speed as M200
HUB stats look 'OK'. There were several errors this morning but it may have been a 'blip'.
Could you create a BQM and post the live (Shared) link?
mutts21
  • 5
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
@mutts21 wrote:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/669a8882a4539404322853eb071be37ef0...
Hopefully that link worked.
The link itself does work. Since the BQM starts when you create it, it will take some time to populate (A few hours).
mutts21
  • 5
I take it the amount of Pre and Post RS errors are not significant, the router had been powered on for about 2 hours.
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Hmmm 2 hours with that many errors isn't great to be honest. The HUB having to correct errors can cause slower speeds.
We'll have to see what the BQM shows.
