Goosh
  • 27
Message 21 of 43
Re: M500 Upgrade is a disaster - Slower speed than M200
139000000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
1139000000-1.737256 qam1
2147000000-237256 qam2
3155000000-2.237256 qam3
4163000000-2.237256 qam4
5171000000-2.537256 qam5
6179000000-2.737256 qam6
7187000000-337256 qam7
8195000000-337256 qam8
9203000000-3.537256 qam9
10211000000-3.537256 qam10
11219000000-3.938256 qam11
12227000000-437256 qam12
13235000000-438256 qam13
14243000000-438256 qam14
15251000000-4.238256 qam15
16259000000-4.438256 qam16
17267000000-4.238256 qam17
18275000000-4.737256 qam18
19283000000-5.537256 qam19
20291000000-537256 qam20
21299000000-4.237256 qam21
22307000000-3.738256 qam22
23315000000-3.938256 qam23
24323000000-438256 qam24
1Locked37.35560
2Locked37.67813
3Locked37.678417
4Locked37.3749207
5Locked37.651420
6Locked37.63790
7Locked37.33768
8Locked37.66070
9Locked37.61890
10Locked37.67952
11Locked38.677798
12Locked37.62280
13Locked38.63280
14Locked38.61480
15Locked38.61830
16Locked38.91730
17Locked38.62220
18Locked37.62490
19Locked37.64560
20Locked37.64070
21Locked37.62710
22Locked38.91790
23Locked38.62190
24Locked38.62160
Goosh
  • 27
Message 22 of 43
16030000043.3512064 qam1
23940000042.8512064 qam4
34620000043512064 qam3
45370000043.3512064 qam2
1ATDMA0010
3ATDMA0020
4ATDMA0000
Goosh
  • 27
Message 23 of 43
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053+voc-b.cm
SFID12462
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID12461
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Andrew-G
  • 8.17K
  • 1.36K
  • 3.7K
Message 24 of 43
Just spoke to the tech team and they've done a remote connection to the Hub3, pushed a software change and I've seen a speed increase to 348mbps on wifi direct through the VM wifi channel
Well, keep an eye on it.  This remote kick up the arts that VM claim they do often doesn't seem to fix problems for any length of time, and that's unsurprising if the fault is line noise or a manky connector.  Your latest stats still show rather poor downstream power, plus far too many post-RS errors.  Even in small numbers, post-RS errors are really bad for latency and speed.
I could be wrong and hopefully am, but I suspect you'll see speeds deteriorate again.
Goosh
  • 27
Message 25 of 43
Cheers Andrew,
That's what I'm expecting as well in all honesty but willing to give them the benefit of the doubt.
On a plus note, the tech team actually listened to me, my setup and my efforts to correct it and didn't have me disconnect or reboot the hub3 etc which was what I was dreading when I rang up to complain.
Will leave the setup exactly as is and see what the crack is on Sunday night
Corey_C
  • 4.83K
  • 243
  • 402
Message 26 of 43
Thanks for your post and updates, Goosh,
Let us know how it goes with your connection.
Cheers,
Corey C
Goosh
  • 27
Message 27 of 43
Hi Corey_C,
I've achieved some increases in speed, but not consistent at all - very hit and miss and not at all above the minimum guarantee.  Unfortunately, my whole housing estate was offline this morning so I was unable to test further as I'm at work (saving grace).
I'll reboot the router when I get home and see what the state of play is but if theres no improvement, I may have to escalate it further.
John_GS
  • 10.72K
  • 554
  • 981
Message 28 of 43
Hi Goosh
Do try the reboot and let us know.
Best,
John_GS
Goosh
  • 27
Message 29 of 43
Hi John,
I'm still getting below par speeds and no consistant speeds.  I did achieve 443 Mbps on VM wifi when I was stood next to the hub but this is below the guaranteed speed.  The current stats are:
139000000
Locked
60300000
Locked
Provisioning State
Online
1139000000-237256 qam1
4163000000-2.437256 qam4
6179000000-337256 qam6
8195000000-3.238256 qam8
10211000000-3.737256 qam10
18275000000-4.537256 qam18
21299000000-4.437256 qam21
1Locked37.3435109
2Locked37.6441129
3Locked37.651637
4Locked37.660087
5Locked37.653443
6Locked37.647244
7Locked37.6129482
8Locked38.645868
9Locked37.630838
10Locked37.621834
11Locked38.651054
12Locked37.615238
13Locked38.613841
14Locked38.69853
15Locked38.68144
16Locked38.69630
17Locked38.69149
18Locked37.68044
19Locked37.615241
20Locked37.615644
21Locked37.612728
22Locked38.98071
23Locked38.67063
24Locked38.97758
16030000043512064 qam1
24620000742.8512064 qam3
33939996142.5512064 qam4
45370001543512064 qam2
1ATDMA0010
3ATDMA0000
4ATDMA0010
Goosh
  • 27
Message 30 of 43
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID16572
Min Traffic Rate0
SFID16571
Min Traffic Rate0
04/10/2021 08:25:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2021 17:14:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 15:06:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 11:00:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/09/2021 00:52:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2021 19:33:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2021 19:32:48Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2021 19:27:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2021 09:05:26criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2021 09:03:6Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2021 09:03:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2021 09:03:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2021 09:03:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2021 19:56:36noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2021 12:48:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2021 14:28:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2021 08:32:32noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2021 01:42:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/09/2021 06:41:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
