Goosh
  • 27
Message 11 of 43
Re: M500 Upgrade is a disaster - Slower speed than M200
Hmmm, thanks for checking.  I might try to factory reset the Hub3 to see if that helps.
Goosh
  • 27
Message 12 of 43
Just done a factory reset on the Hub3 and the speeds have jumped up - Not where they should be as guaranteed minimum is 258 Mbps:
https://www.speedtest.net/result/12062556675
Going to repost the stats since the reboot
Goosh
  • 27
Message 13 of 43
Item Status Comments
227000000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
Andrew-G
  • 8.59K
  • 1.41K
  • 3.97K
Message 14 of 43
I'm unimpressed by the downstream power levels.  VM are cagey about what's permissible, and as low as -6 dBmV has been semi-formally muttered, but I often observe problems at the -5 level, added to which power levels run from -1.7 to -5.4 which is a bit on the rangey side for my liking.
Hang on and see what the forum staff advise - if they can't offer a solution then you'll need to read and invoke the VM minimum speed guarantee, which broadly speaking involves you running tests until you can show a minimum speed below the relevant threshold at least once on three consecutive days.
Goosh
  • 27
Message 15 of 43
1227000000-437256 qam12
2139000000-1.937256 qam1
3147000000-237256 qam2
4155000000-2.237256 qam3
5163000000-2.237256 qam4
6171000000-2.537256 qam5
7179000000-2.937256 qam6
8187000000-337256 qam7
9195000000-3.237256 qam8
10203000000-3.537256 qam9
11211000000-3.537256 qam10
12219000000-3.938256 qam11
13235000000-438256 qam13
14243000000-437256 qam14
15251000000-4.238256 qam15
16259000000-4.437256 qam16
17267000000-4.437256 qam17
18275000000-4.538256 qam18
19283000000-5.537256 qam19
20291000000-5.437256 qam20
21299000000-4.537256 qam21
22307000000-438256 qam22
23315000000-438256 qam23
24323000000-4.238256 qam24
1Locked37.6270
2Locked37.6420
3Locked37.6390
4Locked37.3460
5Locked37.6350
6Locked37.3230
7Locked37.6230
8Locked37.3180
9Locked37.6320
10Locked37.6220
11Locked37.6160
12Locked38.6200
13Locked38.6400
14Locked37.3340
15Locked38.6260
16Locked37.6270
17Locked37.6450
18Locked38.6450
19Locked37.6710
20Locked37.6990
21Locked37.6460
22Locked38.9280
23Locked38.6360
24Locked38.6300
Goosh
  • 27
Message 16 of 43
16030000043512064 qam1
23940000042.5512064 qam4
34620000042.8512064 qam3
45370000043512064 qam2
3ATDMA0000
4ATDMA0000
Goosh
  • 27
Message 17 of 43
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053+voc-b.cm
SFID12298
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID12297
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Goosh
  • 27
Message 18 of 43
Cheers Andrew, I'll be running them quite often to check.
I've added more stats now (got timed out for forum spam :D)
cje85
  • 2.72K
  • 174
  • 727
Trouble shooter
Message 19 of 43
Edit: Ignore this, what I suggested has already been tried
Goosh
  • 27
Message 20 of 43
Just spoke to the tech team and they've done a remote connection to the Hub3, pushed a software change and I've seen a speed increase to 348mbps on wifi direct through the VM wifi channel
Hub3 is in Modem & Router mode, R8000 is in Access Point mode and I'm leaving it like that for 3 days whilst they monitor the HUb3 box.  If it doesn't improve/gets worse, there is the offer of a new box on the table.
I'll post the stats of the box for records now as well.
