alexanderb81
  • 14
Message 1 of 27
M500 Slow LAN and WLAN
Hi All
Hoping someone can help with a strange and unusual issue with my Virgin M500.
I have some slow broadband speeds and have tried all the various troubleshooting methods. This is a new installation, and the engineer reached over 450Mpbs on his app after installation.
A little insight into my setup:
VM Hub 3 in modem mode connected to an Ubiquiti Edge Router X and Unify NanoHD access point.
I have the default VLAN and two other VLANS, none of them are throttled.
I have also turned the Hub into Router mode to do troubleshooting to ensure its not the ER-X
WLAN speeds seem to be faster than Ethernet.
For example, on WLAN i am generally getting 110-150Mbps on speedtest
When i connect using LAN and disabling WLAN, i only manage to get about 70Mbps. i know its usually the other way around so that's whats confusing me. Upload is consistent at 37Mbps on both LAN and WLAN
I have tried with another laptop, and get the same results. tried using cat6 and cat 5 cables, same results.
Below are the stats from the HUB.
1 419000000 5.1 40 256 qam 30
2 187000000 7 40 256 qam 7
3 195000000 7 40 256 qam 8
4 203000000 7 40 256 qam 9
5 211000000 6.9 40 256 qam 10
6 219000000 7 40 256 qam 11
7 227000000 7 40 256 qam 12
8 235000000 6.9 40 256 qam 13
9 243000000 6.8 40 256 qam 14
10 251000000 6.6 40 256 qam 15
11 259000000 6.6 40 256 qam 16
12 267000000 6.6 40 256 qam 17
13 275000000 6.5 40 256 qam 18
14 283000000 6.5 40 256 qam 19
15 291000000 6.5 40 256 qam 20
16 299000000 6.6 40 256 qam 21
17 307000000 6.5 40 256 qam 22
18 315000000 6.5 40 256 qam 23
19 323000000 6.5 40 256 qam 24
20 379000000 5.9 40 256 qam 25
21 387000000 5.8 40 256 qam 26
22 395000000 5.8 40 256 qam 27
23 403000000 5.5 40 256 qam 28
24 411000000 5.4 40 256 qam 29
1 Locked 40.9 3 0
2 Locked 40.3 18 182
3 Locked 40.9 8 0
4 Locked 40.3 26 0
5 Locked 40.9 22 0
6 Locked 40.9 10 0
7 Locked 40.3 8 0
8 Locked 40.9 14 0
9 Locked 40.3 9 0
10 Locked 40.3 13 0
11 Locked 40.3 10 0
12 Locked 40.3 13 0
13 Locked 40.3 7 0
14 Locked 40.9 7 0
15 Locked 40.3 7 0
16 Locked 40.3 11 0
17 Locked 40.9 17 0
18 Locked 40.3 48 0
19 Locked 40.9 19 0
20 Locked 40.3 2 0
21 Locked 40.3 7 0
22 Locked 40.3 10 0
23 Locked 40.3 18 0
24 Locked 40.9 8 0
1 60300000 3.85 5120 64 qam 6
2 53700000 3.875 5120 64 qam 7
3 39400000 3.825 5120 64 qam 9
4 46200000 3.85 5120 64 qam 8
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID 880532
Max Traffic Rate 575000000
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 880531
Max Traffic Rate 38520000
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
30/08/2020 13:26:38 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 13:26:35 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 13:26:34 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 13:26:34 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 13:26:31 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/08/2020 15:41:40 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/08/2020 05:44:51 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 01:39:3 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 01:09:15 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 01:08:53 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 01:07:53 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 01:02:0 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 01:01:55 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 01:01:55 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/08/2020 01:24:33 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2020 11:37:13 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2020 11:33:28 Warning! TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/08/2020 11:33:28 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 27
Re: M500 Slow LAN and WLAN
Can you carry out a couple of speed tests at speedtest.net using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected.
Ensure that the Network Interface Card (NIC) drivers are up to date.
Then post the links to the results on here.
alexanderb81
  • 14
Message 3 of 27
Thanks for replying Mike. Do you mean plugging laptop directly into port 4 of the Hub while in modem mode? I will only be able to do that either do that at lunch time or after work
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 27
Leave the Hub in Modem Mode, disconnect all the ethernet cables then connect to the laptop with a known good cable and retest.
TheChairman
  • 351
  • 23
Up to speed
Message 5 of 27
I can't find the Ubiquiti Edge Router X on there website do you mean the ER-X ?
Regardless the EX-X model does do 1 gig through put as long as fast-path is enable. Even if it isn't it should handle what your network is capable off.
TheChairman
  • 351
  • 23
Up to speed
Message 6 of 27
Okay looking a bit deeper forum posts suggest you need to enable hardware offloading if not the speeds drop one hell of a lot.
https://community.ui.com/questions/EdgeRouter-Lite-NAT-Firewall-performance-tests/ce36aba5-ad41-4ec8...
alexanderb81
  • 14
Message 7 of 27
Thanks TheChairman. I have already enable hardware offloading. but will double check the change had applied.
I will test later today after work directly into the hub with only the laptop and check the speeds i am getting and post the results.
alexanderb81
  • 14
Message 8 of 27
Evening all
Took my laptop upstairs, plugged directly into the hub and restarted the hub. Performed multiple tests with just the laptop connected. results pretty shocking:
60.20
105.85
35.01
83.20
68.24
occasional boosts up to 150 but drops straight back to the 60-80 range
Plugged rest of my equipment back in, restarted the hub again and got these results:
71.6
63.78
65.37
so pretty much the same.
Uploads are always consistent at 37Mbps. At lunch time i managed to see a 215, but that still less than 50% of what im expecting. Any thoughts are appreciated.
Thaks
Alex
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 27
Check that the laptop NIC is set to 100/1000 and the drivers are up to date.
Also try a different ethernet cable or even 2.
alexanderb81
  • 14
Message 10 of 27
Hi there
Drivers up to date and different cables, tested with NIC set to auto-negotiate, got 214.41 and set to 1Gbps full duplex and got 194.76
Yesterday got similar speed at 11:47am of 215.56
