PJMo
  • 5
Message 1 of 5
M500 New Install Speed Problem
Hopefully someone can shed some light on the issue we're having. We recently had Virgin installed with a M500 package. We cannot get any speeds higher than 220Mbps using any method of connection, hardwired (cat6 cable) to the Hub3 or via 5 Ghz Wifi
Does anyone have any suggestions. Have tried numerous times to contact support via the phone.
PJMo
  • 5
Message 2 of 5
Re: M500 New Install Speed Problem
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
138750000
2
38
256 qam
1
2
146750000
1.7
38
256 qam
2
3
154750000
1.9
40
256 qam
3
4
162750000
2
40
256 qam
4
5
170750000
2.4
38
256 qam
5
6
178750000
2.5
38
256 qam
6
7
186750000
2.5
38
256 qam
7
8
194750000
2.5
38
256 qam
8
9
202750000
2.5
38
256 qam
9
10
210750000
2.5
38
256 qam
10
11
218750000
2.5
40
256 qam
11
12
226750000
2.2
38
256 qam
12
13
234750000
2.2
38
256 qam
13
14
242750000
2
38
256 qam
14
15
250750000
1.9
38
256 qam
15
16
258750000
1.7
40
256 qam
16
17
266750000
1.4
40
256 qam
17
18
274750000
1
38
256 qam
18
19
282750000
0.7
38
256 qam
19
20
290750000
0.7
38
256 qam
20
21
298750000
0.7
38
256 qam
21
22
306750000
0.7
38
256 qam
22
23
314750000
0.7
38
256 qam
23
24
322750000
0.9
38
256 qam
24
PJMo
  • 5
Message 3 of 5
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
68
0
2
Locked
38.9
10
0
3
Locked
40.3
8
0
4
Locked
40.3
7
0
5
Locked
38.9
6
0
6
Locked
38.9
34
0
7
Locked
38.9
19
0
8
Locked
38.6
16
0
9
Locked
38.9
18
0
10
Locked
38.9
12
0
11
Locked
40.3
12
0
12
Locked
38.9
5
0
13
Locked
38.9
14
0
14
Locked
38.9
11
0
15
Locked
38.9
50
0
16
Locked
40.3
8
0
17
Locked
40.3
9
0
18
Locked
38.9
9
0
19
Locked
38.9
9
0
20
Locked
38.9
29
0
21
Locked
38.9
29
0
22
Locked
38.9
31
0
23
Locked
38.9
36
0
24
Locked
38.9
17
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53699939
3.175
5120
64 qam
2
2
60299984
3.175
5120
64 qam
1
3
39400025
3.175
5120
64 qam
4
4
46200149
3.175
5120
64 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxxl500u+voc-b.cm
SFID
1996
Max Traffic Rate
575000000
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
1995
Max Traffic Rate
38520000
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
PJMo
  • 5
Message 4 of 5
Time
Priority
Description
19/10/2020 15:20:45
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 15:20:41
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 15:15:16
notice
19/10/2020 15:10:45
critical
19/10/2020 14:08:25
notice
19/10/2020 12:41:0
critical
19/10/2020 08:23:48
notice
17/10/2020 14:01:44
critical
17/10/2020 11:35:42
notice
17/10/2020 11:23:52
critical
17/10/2020 11:08:13
notice
16/10/2020 17:27:42
critical
16/10/2020 16:04:10
notice
01/01/1970 00:11:36
notice
Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:11:9
notice
12/09/2020 00:26:26
critical
10/09/2020 17:18:8
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2020 17:18:8
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/09/2020 21:36:50
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/09/2020 01:31:38
critical
Emily_G
  • 4.82K
  • 209
  • 286
Message 5 of 5
Thanks for the post PJMo.
We can see some upstream power levels so we've booked the next available engineer appointment using your forum information.
Please view the details of the appointment and reschedule if needed on your online account.
Thanks, Emily.
