gainzy2k13
M500 Internet Speed
Hi all, just got the m500 package installed yesterday and speeds are really poor. 30up & 30 down, is there some sort of period you need to wait or should the speeds be instant?
thanks liam
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: M500 Internet Speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
gainzy2k13
1331000000140256 qam25
22030000002.538256 qam9
32110000002.538256 qam10
42190000002.540256 qam11
52270000002.438256 qam12
62350000002.238256 qam13
7243000000238256 qam14
8251000000240256 qam15
9259000000240256 qam16
102670000001.740256 qam17
112750000001.440256 qam18
12283000000140256 qam19
13291000000138256 qam20
14299000000140256 qam21
153070000000.940256 qam22
163150000000.738256 qam23
173230000000.740256 qam24
183390000001.240256 qam26
193470000000.938256 qam27
203550000000.738256 qam28
213630000000.740256 qam29
22371000000140256 qam30
233790000000.938256 qam31
243870000000.740256 qam32
1Locked40.960
2Locked38.940
3Locked38.970
4Locked40.9100
5Locked38.980
6Locked38.960
7Locked38.950
8Locked40.350
9Locked40.360
10Locked40.370
11Locked40.3100
12Locked40.370
13Locked38.9120
14Locked40.340
15Locked40.350
16Locked38.9100
17Locked40.350
18Locked40.350
19Locked38.980
20Locked38.960
21Locked40.990
22Locked40.360
23Locked38.960
24Locked40.310
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
254k;fg87dsfd;kfoA,.iyewrkldJ
SFID3066
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID3065
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
08/01/2021 00:10:22noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 00:09:58Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 23:16:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 23:15:57Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 22:51:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 12:36:42noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 12:36:42ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 11:38:59noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 11:38:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 11:10:57noticeSW download Successful - Via Config file
07/01/2021 11:07:43noticeSW Download INIT - Via Config file
07/01/2021 11:07:34ErrorDisruption during SW download - Power Failure
07/01/2021 11:04:48notice
here is all that info
gainzy2k13
My Quality
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a7757327887b303d4324e97f7cb9fad81556d44a
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you post the Upstream data please.
