TwoMadFan
  • 7
Message 1 of 14
M500 Fibre Broadband plan below minimum guaranteed download speed even with wired connected.
As the title says, even with wired a wired connection the internet speed on speedtest.net was 248 Mbps which is a bit short of the guaranteed download speed, however on my phone or a wireless laptop connection the speed fell to 20 Mbps and 14 Mbps respectively. I have used the Virgin Media Connect throughout the house and not found any black spots for connectivity.
The Downstream, Upstream and Network Logs are attached as screenshots, as well as screenshots of the internet speed tests. I've also copy and pasted the information directly into this post below:
1 483000000 2 40 256 qam 32
2 203000000 2.5 40 256 qam 9
3 211000000 2.7 38 256 qam 10
4 219000000 2.5 40 256 qam 11
5 227000000 2.4 38 256 qam 12
6 235000000 2.4 40 256 qam 13
7 243000000 2.4 40 256 qam 14
8 251000000 2.5 40 256 qam 15
9 259000000 2.5 40 256 qam 16
10 267000000 2.5 40 256 qam 17
11 275000000 2.5 40 256 qam 18
12 283000000 2.7 40 256 qam 19
13 291000000 2.4 38 256 qam 20
14 299000000 2.5 38 256 qam 21
15 307000000 2.2 40 256 qam 22
16 315000000 2.2 40 256 qam 23
17 323000000 2 40 256 qam 24
18 427000000 2.4 40 256 qam 25
19 435000000 2.2 40 256 qam 26
20 443000000 2 40 256 qam 27
21 451000000 2.4 38 256 qam 28
22 459000000 2.2 38 256 qam 29
23 467000000 2.2 38 256 qam 30
24 475000000 2 40 256 qam 31
1 Locked 40.3 8261 1979
2 Locked 40.9 314276 61845
3 Locked 38.9 159388 38226
4 Locked 40.3 148360 40507
5 Locked 38.9 316093 60280
6 Locked 40.3 256314 49597
7 Locked 40.3 91798 23277
8 Locked 40.9 80531 19808
9 Locked 40.3 105913 22357
10 Locked 40.3 84106 24316
11 Locked 40.9 93173 22742
12 Locked 40.9 66449 19439
13 Locked 38.9 68155 17231
14 Locked 38.9 57143 14903
15 Locked 40.3 47482 9758
16 Locked 40.3 46051 5419
17 Locked 40.3 56594 10257
18 Locked 40.3 16099 1834
19 Locked 40.3 15556 1918
20 Locked 40.3 16273 2987
21 Locked 38.9 15832 2393
22 Locked 38.9 15431 1899
23 Locked 38.9 7522 1199
24 Locked 40.3 5076 1247
1 39400041 4.45 5120 64 qam 6
2 25799989 4.35 5120 64 qam 8
3 46200145 4.475 5120 64 qam 5
4 32600132 4.425 5120 64 qam 7
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
28/09/2020 14:41:16 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 14:39:0 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 14:05:45 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 10:31:6 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 05:08:55 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/09/2020 05:00:33 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 22:43:10 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 22:41:29 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 20:52:52 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 17:59:27 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/09/2020 08:01:46 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 00:21:3 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 13:30:5 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 09:11:25 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/09/2020 18:46:55 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/09/2020 16:23:9 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/09/2020 04:22:28 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/09/2020 09:10:33 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 16:25:55 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/09/2020 15:39:25 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Laptop.pngPhone A70.jpgWired Laptop.pngDownstream bonded channels.pngNetwork Log.pngUpstream bonded channels.png
Martin_N
  • 5.56K
  • 232
  • 318
Message 2 of 14
Re: M500 Fibre Broadband plan below minimum guaranteed download speed even with wired connected.
Hi TwoMadFan,
Thank you for your post and welcome to the community.
Our apologies for any broadband related issue you're having. This certainly isn't what we like to see.
Can you confirm for me the devices you've been conducting the speed tests on?
Do you see any increase or decrease in speed at certain times?
^Martin
TwoMadFan
  • 7
Message 3 of 14
The devices we use are android phones and windows laptops only. The internet speed is relatively consistent throughout the day.
Martin_N
  • 5.56K
  • 232
  • 318
Message 4 of 14
How many devices do you have connected to the hub? Do you have our Virgin Media Connect App? If yes have you checked out our Blackspot checker?
^Martin
TwoMadFan
  • 7
Message 5 of 14
There are about 8 devices connected, 7 of them via wifi and 1 with ethernet. As I said in the original post, the Virgin Media connect app showed there arent any blackspots in the house.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 14
Forget Wi-Fi for now.
Use a Cat 5E / 6 ethernet cable connected to a 1Gbs capable Pc/Mac/Chromebook and no other devices and carry out speed tests at speedtest.net then report back the speeds that you get.
TwoMadFan
  • 7
Message 7 of 14
TwoMadFan
  • 7
Message 8 of 14
For me the original screenshot I uploaded is stuck on being verified so I've uploaded it again here.
Martin_N
  • 5.56K
  • 232
  • 318
Message 9 of 14
Can you confirm what the speed is for us?
^Martin
TwoMadFan
  • 7
Message 10 of 14
The speed when using a Cat 6 ethernet cable is 355 Mbps, however this is during offpeak times. For all the other devices that use wifi the speed is far below the minimum guaranteed speed and even the ethernet cable falls below the guaranteed speed at certain times in the day.
