BenE11
  • 16
Message 1 of 9
M350 very slow upload speed
Hi, as per title. Just seen another thread so will follow protocol. Can I book an engineer from here like old times?
12027500003.538256 qam9
22107500003.538256 qam10
32187500003.738256 qam11
42267500003.738256 qam12
52347500003.738256 qam13
62427500003.538256 qam14
72507500003.738256 qam15
82587500003.738256 qam16
9266750000438256 qam17
102747500004.138256 qam18
112827500004.538256 qam19
122907500004.638256 qam20
132987500004.938256 qam21
143067500004.938256 qam22
15314750000538256 qam23
16322750000538256 qam24
17330750000538256 qam25
183707500005.138256 qam26
193787500005.538256 qam27
203867500005.638256 qam28
213947500005.538256 qam29
22402750000538256 qam30
234107500004.538256 qam31
244187500004.438256 qam32
1Locked38.9530
2Locked38.6290
3Locked38.9350
4Locked38.9330
5Locked38.9350
6Locked38.6350
7Locked38.9400
8Locked38.9420
9Locked38.9240
10Locked38.6290
11Locked38.9480
12Locked38.6700
13Locked38.6560
14Locked38.9550
15Locked38.9720
16Locked38.9630
17Locked38.9500
18Locked38.9860
19Locked38.91210
20Locked38.91120
21Locked38.91720
22Locked38.61850
23Locked38.92670
24Locked38.63140
BenE11
  • 16
Message 2 of 9
Re: M350 very slow upload speed
14620000039512064 qam7
25369991651.3512016 qam6
33940000038.8512064 qam8
1ATDMA00180
2ATDMA0080
3ATDMA0000
BenE11
  • 16
Message 3 of 9
27/01/2021 17:26:33criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:26:9criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:26:9criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:20:57criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:20:37noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:19:45criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:19:21criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:19:21criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:12:56criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:12:32criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:12:32criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:06:8criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:05:44criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 17:05:44criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 16:59:19criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 16:58:55criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 16:58:55criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 16:52:31criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 16:52:7criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 16:52:7criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
BenE11
  • 16
Message 4 of 9
BQM link (I guess needs time to populate…)
https://www.thinkbroadband.com/broadband/monitoring/quality/share/cd76d54a068e0cbae8b3555c3b62142c4e7fbba1
Thanks for any help!
BenE11
  • 16
Message 5 of 9
I've had to enable network pings for the BQM graph to work! Another 24 hour wait I guess.
Looks like many others with the same issue in the area.
I've noticed on my wall-box outside, that my neighbours connection is on a splitter from my own. Is this standard practice or an engineer hack? What if everyone with this in place had an issue? (Uneducated guess I know…)
conman33158
  • 674
  • 63
  • 86
Superfast
Message 6 of 9
You have a stream missing as there should be 4 and the one highlighted in red should be 64 QAM, you have a lot of errors in your network log which isn't good either. Will have to let the BQM run for a while before we can get any info from that.
Have you tried a factory reset? Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection.
If it doesn't improve after a reset you will need an engineer visit to put these right. Best to ring VM after 8am or alternatively you can wait here for a Virgin staff member to pick it up, typically between 5-10 days, sometime sooner, sometimes later depending on how busy they are.
BenE11
  • 16
Message 7 of 9
Thanks, that's interesting. I can see there's been a remote reboot in the log, and now I have only two upstream, but speed is improved to about 9mb.
Will try another reset when everyone is out of school/ work. (I did do this a couple of weeks ago but half the street was out of service.)
14620000039.5512064 qam7
23940000039.3512064 qam8
1ATDMA00180
conman33158
  • 674
  • 63
  • 86
Superfast
Message 8 of 9
From what I can see of your BQM that's not looking good either, could be possible over utilisation which is never a good sign 😞 Although this could just be down to a line fault.
BenE11
  • 16
Message 9 of 9
Pulled a 6db attenuator off the line and did a quick reboot, seems much improved. I have no idea if the attenuator was at fault or if they have fixed centrally though…
25370000039.3512064 qam6
33940000039.3512064 qam8
46030000039.3512064 qam5
3ATDMA0000
4ATDMA0000
