  • 11
Message 1 of 18
M350 speed not achieved - same problem for someone else
On Tuesday, MarkVidler posted saying he was not getting the promised M350 speed.  I posted that I too was not getting the promised service.  Two days later I am encouraged to post the same problem again, but separately for all to see.  Here it is:
I am in south Edinburgh, Bruntsfield and have been monitoring my network performance over the last month using the thinkbroadband.com speedtest tool recommended by Virgin.  As you can see from the table below, with the exception of the 11/12th April when I got the service I am paying for, its otherwise been very poor.
I am using a modern Dell OptiPlex i5 16Mb  Win10 constant updates. Cat 6 direct into hub 3. No big downloads. All connectors checked and tight. Yes, yes I've rebooted everything frequently. It makes no difference.
I have been a customer since the United Artists days.  Virgin changed the network capacitors 3 years ago which helped back then.  Only now having to work form home, do I realise how poor the service is I'm getting at present, and how hard it has become to contact Virgin.  Their online connection check always comes back green - everything OK. However, clearly its not, and its hard to get them to pay attention to this at this covid-19 distracting time.
Date
Down HTTPx6
Down HTTPx1
Upstream
ISP
Thu30/04/2020 09:30
16.50 Mbps
17.19 Mbps
4.60 Mbps
Virgin Media
Tue 28/04/2020 14:17
16.98 Mbps
17.41 Mbps
4.53 Mbps
Virgin Media
Tue 28/04/2020 14:04
17.23 Mbps
17.45 Mbps
4.51 Mbps
Virgin Media
Fri 24/04/2020 09:39
17.09 Mbps
17.27 Mbps
4.68 Mbps
Virgin Media
Tue 21/04/2020 12:07
10.87 Mbps
10.85 Mbps
4.33 Mbps
Virgin Media
Tue 21/04/2020 10:27
0.74 Mbps
0.34 Mbps
0.55 Mbps
Virgin Media
Tue 14/04/2020 12:00
9.81 Mbps
10.02 Mbps
1.95 Mbps
Virgin Media
Mon 13/04/2020 10:48
17.01 Mbps
14.85 Mbps
4.84 Mbps
Virgin Media
Sun 12/04/2020 15:48
317.10 Mbps
122.21 Mbps
35.78 Mbps
Virgin Media
Sat 11/04/2020 21:24
320.83 Mbps
140.66 Mbps
31.94 Mbps
Virgin Media
Sat 11/04/2020 18:19
323.66 Mbps
97.49 Mbps
35.70 Mbps
Virgin Media
Thu 09/04/2020 12:11
15.78 Mbps
14.25 Mbps
3.51 Mbps
Virgin Media
Thu 09/04/2020 09:47
16.57 Mbps
17.20 Mbps
3.97 Mbps
Virgin Media
Sat 09/11/2019 21:46
66.06 Mbps
47.53 Mbps
33.87 Mbps
Virgin Media
Does anyone else have a sustained record of poor performance like this?
I am not a NHS or priority customer, so I will wait until its all over to see then if this is the best Virgin can do.
  • 2.06K
  • 127
  • 401
Problem sorter
Message 2 of 18
Re: M350 speed not achieved - same problem for someone else
Post the logs from your Hub3 please, along with the Downstream and Upstream information. Also post your
BQM monitor graph.
  • 11
Message 3 of 18
Hmm. Just setup BQM monitor graph. New concept to me.  It will take time to build up data to view.
Running the Hub 3 diagnostics shows no problem with Broadband connection or Ethernet Connection.  Not sure where to get the log data from that (no obvious file download) but am a bit reluctant to upload such data onto this forum.  Thanks for your offer of help anyway. I'll wait till I can get a hold of a Virgin Media support person.
  • 2.48K
  • 156
  • 643
Problem sorter
Message 4 of 18
There is no risk in posting your hub stats here, they don't contain any personal information, just details about the quality of the signal. Everyone gets asked to post them as it's the best way to identify any connection problems.
Go to http://192.168.0.1 but don't sign in, just click Check Router Status.  Then copy/paste the Downstream, Upstream and Network Log.
  • 11
Message 5 of 18
Strange. I posted a reply to this an hour ago and it didn't appear because it is flagging "highlighted errors" with no actual highlighted anything.  Here is the post again, this time pasted through MS Word first.  Thanks.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
411000000
-5.7
38
256 qam
31
2
203000000
-7.5
37
256 qam
9
3
211000000
-7.4
36
256 qam
10
4
219000000
-7.2
37
256 qam
11
5
227000000
-7
36
256 qam
12
6
235000000
-7.2
37
256 qam
13
7
243000000
-7.5
37
256 qam
14
8
251000000
-7
36
256 qam
15
9
259000000
-7
36
256 qam
16
10
267000000
-7
36
256 qam
17
11
275000000
-7.5
36
256 qam
18
12
283000000
-7
37
256 qam
19
13
291000000
-6.9
37
256 qam
20
14
299000000
-7.2
36
256 qam
21
15
307000000
-6.7
37
256 qam
22
16
315000000
-6.5
37
256 qam
23
17
323000000
-6
37
256 qam
24
18
363000000
-5.7
37
256 qam
25
19
371000000
-5.7
37
256 qam
26
20
379000000
-5.5
38
256 qam
27
21
387000000
-5.9
37
256 qam
28
22
395000000
-5.4
38
256 qam
29
23
403000000
-5.2
38
256 qam
30
24
419000000
-5.5
38
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
22
0
2
Locked
37.3
7
0
3
Locked
36.6
7
0
4
Locked
37.3
7
0
5
Locked
36.6
6
0
6
Locked
37.3
8
0
7
Locked
37.3
0
0
8
Locked
36.6
6
0
9
Locked
36.6
5
0
10
Locked
36.6
6
0
11
Locked
36.6
1
0
12
Locked
37.6
5
0
13
Locked
37.3
6
0
14
Locked
36.6
7
0
15
Locked
37.3
12
0
16
Locked
37.6
13
0
17
Locked
37.3
9
0
18
Locked
37.3
4
0
19
Locked
37.6
7
0
20
Locked
38.6
15
0
21
Locked
37.3
12
0
22
Locked
38.6
16
0
23
Locked
38.6
21
0
24
Locked
38.6
16
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400017
4.875
5120
64 qam
4
2
46200007
5.025
5120
64 qam
3
3
53700051
5.075
5120
64 qam
2
4
60300017
5.1
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
30/04/2020 10:33:6
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2020 10:31:9
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2020 06:38:49
critical
28/04/2020 05:43:20
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2020 04:13:17
critical
19/04/2020 21:09:51
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/04/2020 21:09:51
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/04/2020 00:14:19
Error
16/04/2020 07:27:27
critical
15/04/2020 09:21:49
Error
14/04/2020 19:58:50
critical
14/04/2020 17:36:49
Error
08/04/2020 12:41:39
critical
08/04/2020 00:16:50
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 23:38:21
critical
07/04/2020 23:30:53
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 23:30:1
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2020 23:30:1
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2020 09:34:56
critical
02/04/2020 08:49:26
Error
  • 20.96K
  • 1.13K
  • 2.7K
Message 6 of 18
The downstream levels are too low.
Is there an attenuator fitted to the back of the hub?
  • 11
Message 7 of 18
Are either of these attenuators?  Even if fitted, it worked fine on April 11/12. Full speed.
  • 20.96K
  • 1.13K
  • 2.7K
Message 8 of 18
Pictures won’t be approved until an admin allows them.
Does it look like this:
https://th.bing.com/th/id/OIP.yv65pAljDXqMRhMyjhr3LQHaHa?pid=Api&dpr=3
  • 11
Message 9 of 18
No.  I'm pretty sure I don't have one.  Straight from cable boxes (pictured) into hub.
  • 5.33K
  • 602
  • 1.77K
Message 10 of 18
@mssedin As Gary says you have some downstream power levels that are too low, so will need an engineer to visit and adjust them.  The recommended range is between -6 and +10.  You can try to get through to VM on the phone to book an engineer visit or wait for one of the forum team to get to this thread.
A couple of things, VM don't recommend the TB speed test, they recommend the speedtest.net one as it has VM test servers which can help to show if any speed issues are within the VM network or external.  They do however recommend the BQM tool from TB for helping to spot some issues.
Also have you got any speed test results that are not at peak times?  Pre crisis peak times were roughly 5pm to 11pm weekdays and all weekend, but during this crisis that has changed to roughly 7am to midnight weekdays and all weekends.  While I'm sure you need an engineer to visit and sort out your power levels you may also be impacted by a local utilisation issue which may still limit your speeds during the day.  This manifests as slow speeds at peak times and full speed at non peak times.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
