alob
  • 21
M350 speed never faster than 90Mbps on wired connection
I have only just been made aware about the speed promises whilst negotiating my package with virgin.
I have had M350 for over a year and everytime i have run a speed test it is around 90Mbps (direct ethernet to virgin hub). This is way below the guaranteed speeds.
Is this normal?
Should i complain?
Tags (4)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: M350 speed never faster than 90Mbps on wired connection
The speed that you are getting is indicative of a Network Interface Card (NIC) set to 100/100.
In reality it needs to be set at 1000/1000.
You need to go into the device settings and check and adjust if possible.
DJ_Shadow1966
  • 7.15K
  • 1.36K
  • 2.03K
Hello
From what you have said this could be either cable or that the network card isn't running at 1000mbps.
First thing I would recommend is too check that the cable you are running is at least Cat 5e, have a look on the cable it will be marked on it.
Have a logbook at https://www.tenforums.com/tutorials/75371-see-network-adapter-speed-windows-10-a.html#option1 which tells you how to find the network speed of your network card.
Regards Mike
alob
  • 21
Thanks to both replies - sometimes pointing out the obvious helps. Plugged a macbook pro rather than laptop with netwrok dongle direct to hub and now getting 250Mbps
