on 26-06-2020 13:01
After switching to a new broadband contract 1 month ago, from M100 to M350 despite having a really good download speed, I'm experiencing really slow upload speed.
As I'm working in video fields my most important needs are to upload files with a correct upload speed, that is essential.
The average speed is told to be 35mbps on the virgin media website, after testing everyday with a few different speedtest i'm always getting the same speed result.
The maximum on my hub goes on 6mbps, which is really far from the 35mbps expected.
I rebooted the HUB multiple times, placed it in a happy area, I'm connected via ethernet cable to my computer.
After trying multiple times to call the costumer service, I never get any answer. As reading the other thread on the forum I found out that I'm not the only one experiencing this issue...
So I'm trying to reaching someone from Virgin media here to find a solution as fast as possible to my problem, as I'm paying right now for a service that doesn't worth what Virgin media sells.
Any recommendation that would help my problem is welcome !
Pierre
11-09-2020 14:05 - edited 11-09-2020 14:10
@lavers27 wrote:Hello,
... snip ...
Thanks by advance for finding a solution to my problem, I mean by that : Send a someone to fix the problem, reduce the price I'm paying etc
If you speed test to Raleigh-Durham USA, and Atlanta USA you are unlikely to get full speed.
What is the URL of the site where you did those speed tests ?
Can you try again to a local VM Server using speedtest.com.
on 21-09-2020 09:45
Hi Hollie,
Rebooted the rooter but the speed is still the same, this is really impacting the speed of my work and I need a quick solution.
What about you send a technician if something can't be diagnosticed from distance ? Thanks by advance, I'm paying 3 times the price I should pay
from a few months this is really unbearable.
Thanks for your reply with a good solution as I'm really tired about having to get back everytime to hear some floating answers, and still having speed issues that are impacting my work and my money !
on 27-09-2020 10:52
Hi lavers27,
I can completely appreciate that you need this to be working properly for your work.
I've had a look at your services, and you've been having prolonged signal issues. This is something that needs a technician visit to fix so I'd like to get that arranged.
I'll pop you a quick private message, and we'll get that sorted out.
Melissa
on 20-09-2021 23:13
Did this ever get fixed for you? I just upgraded to M350 and my upload is 20Mbit instead of the promised 36-50.
The tech support was pretty much useless, after pulling half my house apart so I'd have something to plug into the terrible hub 3 (as they won't trust my Linksys built-in stuff) the answer was 'oh, there's a known issue that should be resolved in 24 hours'.
on 23-09-2021 11:10
Hi warlockuk, thanks for getting in touch.
Sorry to hear you've not been getting the expected upload speeds on your M350 broadband. Taking a look into this using your forum info I can see there was a known issue earlier this week which has since been deemed to be resolved, and I can't see any other obvious issues at this stage, so I hope that means things have improved for you now?
Please keep us updated if you still need help getting this sorted.
Tom
