ad5665
  • 7
Message 1 of 11
M350 slow speed and high latency for the last 2 weeks
Hey I've been having issues with my speed and latency for the last 2 weeks.
Up until this point I've had little issues and always seem to max out my 350 connection.
Currently I'm only getting 81Mbps on fast.com This used around 400Mbps.
Latency is, 14ms unloaded, 278ms loaded.
Upload speed is fine at 41Mbps
My setup is Superhub3 in modem mode > pfsense > gigabit switch > pc
https://www.thinkbroadband.com/broadband/monitoring/quality/share/21e2971039c108b70304d3e3707c7617b56a870e
Router status
Standard specification compliant: DOCSIS 3.0
Hardware version: 10
Software version: 9.1.1912.302
Status:
331000000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
Downstream
13310000006.340256 qam25
2267000000740256 qam17
32750000006.640256 qam18
42830000006.640256 qam19
52910000006.540256 qam20
62990000006.540256 qam21
73070000006.140256 qam22
83150000006.140256 qam23
93230000006.440256 qam24
103710000005.940256 qam26
11379000000640256 qam27
12387000000640256 qam28
133950000006.140256 qam29
144030000006.440256 qam30
154110000006.440256 qam31
164190000006.140256 qam32
17427000000640256 qam33
184350000005.540256 qam34
194430000005.540256 qam35
204510000005.440256 qam36
214590000005.540256 qam37
224670000005.540256 qam38
234750000005.440256 qam39
244830000005.340256 qam40
1Locked40.350
2Locked40.340
3Locked40.960
4Locked40.950
5Locked40.350
6Locked40.350
7Locked40.3190
8Locked40.9170
9Locked40.960
10Locked40.910
11Locked40.350
12Locked40.950
13Locked40.9190
14Locked40.3190
15Locked40.9180
16Locked40.3170
17Locked40.3200
18Locked40.900
19Locked40.970
20Locked40.360
21Locked40.300
22Locked40.340
23Locked40.350
24Locked40.350
ad5665
  • 7
Message 2 of 11
Re: M350 slow speed and high latency for the last 2 weeks
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13940000044.5512064 qam6
24620000045512064 qam5
33260000044.3512064 qam7
42580000043.3512064 qam8
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA000
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062+voc-b.cm
SFID1634876
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID1634875
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Network LogTime Priority Description
13/11/2020 21:01:23noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 22:56:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 06:53:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 06:34:12criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 06:30:18Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 06:30:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 06:30:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 06:30:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 06:30:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 06:30:10Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 06:30:10criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 06:30:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 23:31:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 12:19:1ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 14:07:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 21:52:43noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 21:52:36Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 18:27:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 01:28:31ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 21:16:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 11
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Modem Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
ad5665
  • 7
Message 4 of 11
Ran from pfsense, other devices were connected but I can see from the traffic graphs in pfsense that no other devices were using brandwidth
[2.4.5-RELEASE][admin@pfSense.localdomain]/root: speedtest-cli
Retrieving speedtest.net configuration...
Testing from Virgin Media ([REMOVED])...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Iomart (Leicester) [30.39 km]: 39.07 ms
Testing download speed................................................................................
Download: 59.82 Mbit/s
Testing upload speed......................................................................................................
Upload: 36.69 Mbit/s
fyi the link between superhub and pfsense is cat6
 [MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
ad5665
  • 7
Message 5 of 11
For most of the day it's been ok, still only getting 200Mbs but latency was acceptable.
However around 6PM I started to notice slowness. fast.com was reporting 300ms+ and only 60Mbs download.
I've also noticed that it seems to be common at peak times.
To test to ensure it wasn't my pfsense box, last night (2am blip below) I put my superhub back into router mode and connected only my laptop using an ethernet cable. Speed and latency were identical to modem mode/pfsense.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 11
You need to test using a direct connection at speedtest.net
ad5665
  • 7
Message 7 of 11
Tested from pfsense, this is a direct connection.
I also put a rule in place before running the test stop lan traffic going through the wan.
[2.4.5-RELEASE][admin@pfSense.localdomain]/root: ifconfig em0
em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=2098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
ether **:**:**:**:**:**
hwaddr **:**:**:**:**:**
inet6 fe80::204:a7ff:fe09:e45e%em0 prefixlen 64 scopeid 0x1
inet [REMOVED] netmask 0xfffffc00 broadcast 86.25.231.255
nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
Hosted by IDAQ Ltd (Sheffield) [36.35 km]: 26.823 ms
Download: 87.96 Mbit/s
Upload: 34.44 Mbit/s
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 11
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
ad5665
  • 7
Message 9 of 11
As it's in Modem mode, it doesn't show the device pages.
However in pfsense it reports full gigabit. I've also tried using another cable
WAN   1000baseT <full-duplex> [REMOVED]
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 11
You need to test without the pfsense in the system.
