  • 34
Message 1 of 25
M350 slow download speed
Hiya - have been on an M350 package for about a year. Not many issues, but logged on this morning and download speed really slow (15Mbps). This is in a PC hardwired connection
Re-booted Hub3 twice and now getting between 50 and 80Mbs but it's really inconsistent. Upload seems stable at 35Mbps as expected.
No issues reported in my area, Hub3 diagnostics don't show an issue, and no recent changes to my hardware in the last few months. Grateful for a test and check to see what the issue might be. Will post HuB stat's below
  • 34
Message 2 of 25
Re: M350 slow download speed
Item Status Comments
299000000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
1 299000000 0.5 40 256 qam 21
2 139000000 -0.2 40 256 qam 1
3 147000000 0 40 256 qam 2
4 155000000 0 38 256 qam 3
5 163000000 0.2 38 256 qam 4
6 171000000 0 40 256 qam 5
7 179000000 0 40 256 qam 6
8 187000000 0.2 40 256 qam 7
9 195000000 -0.2 40 256 qam 8
10 203000000 0 40 256 qam 9
11 211000000 0 40 256 qam 10
12 219000000 -0.2 33 256 qam 11
13 227000000 0 35 256 qam 12
14 235000000 -0.4 40 256 qam 13
15 243000000 -0.7 40 256 qam 14
16 251000000 -0.4 40 256 qam 15
17 259000000 -0.4 40 256 qam 16
18 267000000 -0.2 40 256 qam 17
19 275000000 0.2 40 256 qam 18
20 283000000 0.2 40 256 qam 19
21 291000000 0.4 40 256 qam 20
22 307000000 0.5 40 256 qam 22
23 315000000 0.7 40 256 qam 23
24 323000000 0.7 40 256 qam 24
1 Locked 40.3 5 0
2 Locked 40.3 14 0
3 Locked 40.3 6 0
4 Locked 38.9 30 0
5 Locked 38.9 131 0
6 Locked 40.3 10 0
7 Locked 40.3 5 0
8 Locked 40.3 6 0
9 Locked 40.3 1 0
10 Locked 40.3 4 0
11 Locked 40.3 5 0
12 Locked 33.4 55972 1612
13 Locked 35 91 0
14 Locked 40.3 5 0
15 Locked 40.9 0 0
16 Locked 40.3 6 0
17 Locked 40.3 5 0
18 Locked 40.3 0 0
19 Locked 40.9 4 0
20 Locked 40.9 5 0
21 Locked 40.3 7 0
22 Locked 40.3 5 0
23 Locked 40.9 4 0
24 Locked 40.9 5 0
1 39400000 4.45 5120 64 qam 7
2 60300000 4.575 5120 64 qam 1
3 53700000 4.525 5120 64 qam 2
4 46200000 4.475 5120 64 qam 3
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxl35016u-b.cm
SFID 297404
Max Traffic Rate 402500089
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 297403
Max Traffic Rate 38500089
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
19/01/2020 19:18:20 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2020 01:58:33 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2020 04:02:38 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2020 17:01:54 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2020 18:20:29 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2020 21:55:5 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2020 03:30:9 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2020 10:48:0 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2020 13:23:4 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2020 15:47:32 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2020 19:15:9 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2020 20:43:34 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2020 20:56:54 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2020 01:37:57 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2020 03:07:39 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2020 07:24:13 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2020 09:02:1 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2020 09:12:53 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 3.57K
  • 578
  • 1.41K
Message 3 of 25
Power levels are good, upstream looks OK, but your signal to noise ratio on channel 12 is too low, and that's also shown in the error counts.  Because of the way that a cable connection works, having one channel not performing can destroy performance.
Wait for the forum staff to pick this up, if it is a known area issue then they'll provide a fault reference and a fix date, if not they'll need to book you a technician visit.  If you're feeling both lucky and brave you can phone this in, personally I would avoid any contact with VM's dreadful offshore call centre.
  • 1.25K
  • 56
  • 115
Message 4 of 25
Hi LENSMAN01,
Thank you for your post, I will happily book an engineer to come and have a look at what's going on with your broadband, I will pop you over a private message asking for some details, just keep an eye out for the purple envelope 🙂
Zoie
  • 34
Message 5 of 25
Thanks very much - have provided details to Zoie on private message for investigation and if necessary an engineer visit
  • 34
Message 6 of 25
Hi - Quick update on this.
Engineer visit last Friday - no fault found and it's been fine for a bit more than a week. Then today, same issue as before with Downstream speeds ranging from 40 to 100 Mbps. Pasting levels below, which look to be all over the place... 3 Hub re-boots have not made any improvement and Netflix / Amazon is currently unwatchable. Oh and pin is up around 17ms... as opposed to 7ms normally. Any help / suggestions gratefully received ...
12990000001.240256 qam21
21870000000.740256 qam7
31950000000.440256 qam8
42030000000.540256 qam9
52110000000.540256 qam10
62190000000.234256 qam11
72270000000.535256 qam12
82350000000.240256 qam13
9243000000-0.240256 qam14
102510000000.240256 qam15
112590000000.240256 qam16
122670000000.540256 qam17
132750000000.940256 qam18
142830000000.940256 qam19
15291000000140256 qam20
163070000001.240256 qam22
173150000001.440256 qam23
183230000001.440256 qam24
193310000001.940256 qam25
203390000001.540256 qam26
213470000002.240256 qam27
22355000000240256 qam28
233630000002.240256 qam29
243710000002.540256 qam30
1Locked40.360
2Locked40.3170
3Locked40.950
4Locked40.350
5Locked40.350
6Locked35590
7Locked36.650
8Locked40.350
9Locked40.300
10Locked40.350
11Locked40.300
12Locked40.900
13Locked40.950
14Locked40.340
15Locked40.330
16Locked40.350
17Locked40.350
18Locked40.910
19Locked40.3190
20Locked40.3130
21Locked40.3200
22Locked40.3140
23Locked40.310
24Locked40.900
  • 15.75K
  • 1.65K
  • 2.69K
Message 7 of 25
Out of interest have you tried with a couple of alternative browsers? There are a number of recent threads on here whereby their browser of choice has suddenly started limiting speeds - Chrome is particularly guilty!
Worth a try.
https://community.virginmedia.com/t5/Speed/Another-slow-speed-on-M350-area-20/m-p/4138618#M219126
https://community.virginmedia.com/t5/Speed/Slow-broadband/td-p/3960227
https://community.virginmedia.com/t5/Speed/Etherent-speed-slow/m-p/3912102#M202773
https://community.virginmedia.com/t5/Speed/Speed-Check-Only-get-maximum-80-instead-of-100/td-p/39522...
  • 34
Message 8 of 25
Thanks for the thought but I get the same issue on my Newsgroup client (about 1/4 of normal speed) and streaming services are currently not able to render in 4K so clearly a network issue. Cheers
  • 7.1K
  • 526
  • 920
Legend
Message 9 of 25
Or an upload issue at the other end.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 34
Message 10 of 25
Unlikely a far end upload issue,  as I'm getting the issue across multiple services... streaming, browser download, newsgroup client, etc
