gooseman909
  • 9
Message 1 of 14
M350 running at 25-35mbs
Speed was fine when I first joined a couple of weeks ago but for the last week the Internet speeds has been spotty at best and not gone above 50mbs. I've followed the guidance in the app but nothing is changing. Any help would be very much appreciated! Thanks
Aaron2
  • 867
  • 98
  • 161
Well-informed
Message 2 of 14
Re: M350 running at 25-35mbs
How are you running your speed checks? Ethernet or WiFi?
** I work for VirginMedia but all opinions posted here are my own.
gooseman909
  • 9
Message 3 of 14
I ran the speed check on my phone using WiFi. But I have some football playing on amazon prime on my firestick which has an ethernet connection. And it's buffering (or fuzzing out) every few minutes or so
gooseman909
  • 9
Message 4 of 14
Could I have some further help to this please? Thanks.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 14
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
gooseman909
  • 9
Message 6 of 14
56.27
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 14
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
gooseman909
  • 9
Message 8 of 14
Currently 100mbs.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 14
@gooseman909 wrote:
Currently 100mbs.
That tells us that either the Network Interface Card (NIC) in the device is set wrong / too old or the ethernet cable is not capable of the required speeds.
First thing is to try a different Cat5e or better cable.
If that doesn't work check the Link Speed of the NIC in the device settings.
gooseman909
  • 9
Message 10 of 14
So I've just asked my wife to do a speed test on her phone and she is getting nearly 400mbs. Any ideas why it would be so different? My virgin TV box is saying 1000mbs on my connected devices. My firestick is 100 and my phone is 30 🤣
