lrussell2006
  • 6
Message 1 of 5
M350 Upload Speed Less than 2mbps
I have M350 which was great up until the last two months where the upload speed drops to less than 2mbps in the afternoon / evening and then randomly at other times it jumps straight back to the 30+mbps range.
The download speed never changes and stays at a constant 350-370mbps.
I recently got sent a Hub 4 which I thought may have fixed the issue but it hasn't at all. I use it in Modem Mode and I used to be able to access the hub 3 by going to the DNS IP address but with the Hub 4 I can no longer seem to access it behind the router, happy to send connection details if someone can tell me how to access it behind my router.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 5
Re: M350 Upload Speed Less than 2mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 5
Can you please
lrussell2006
  • 6
Message 4 of 5
https://www.thinkbroadband.com/broadband/monitoring/quality/share/33974c0c54c3b35a734080bee299d25d42...
I've been running it for a few weeks now so hopefully it might tell you something.
I tried accessing my hub 4 in modem mode through 192.168.100.1 and it doesn't connect, any other ideas, I've heard this is an issue with the hub 4 in modem mode?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 5
If you can't access the Hub on 192.168.100.1 you will need to factory reset the Hub.
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once the lights are stabilised check your system again.
