botchok5
  • 13
Message 1 of 8
M350 Terrible Upload Speed | Brighton
Received my upgrade self install pack equipment yesterday and it was working perfect. And now, it looks like the honeymoon period is over after 24hrs. It's impossible to work from home, as I have to upload a lot of documents.
I'm based in Brighton.
My Superhub 3 is in modem mode, I'm using my own Asus AC5300 router and I'm connected via ethernet. This is currently my regular (non vpn) speed:
830 Kbps upload speed. Might as well not give me an upload speed at this rate. YIKES!
Tags (3)
jb66
  • 12.43K
  • 925
  • 1.83K
Message 2 of 8
Re: M350 Terrible Upload Speed | Brighton
And the speed directly connected to the hub?
botchok5
  • 13
Message 3 of 8
1138750000340256 qam1
2146750000340256 qam2
3154750000340256 qam3
41627500002.740256 qam4
51707500002.940256 qam5
61787500002.740256 qam6
71867500002.740256 qam7
81947500002.540256 qam8
92027500002.540256 qam9
102107500002.438256 qam10
112187500002.240256 qam11
12226750000238256 qam12
132347500001.940256 qam13
142427500001.540256 qam14
152507500001.740256 qam15
16258750000240256 qam16
172667500002.240256 qam17
182747500002.240256 qam18
192827500002.240256 qam19
202907500002.240256 qam20
212987500002.440256 qam21
223067500002.440256 qam22
233147500002.540256 qam23
243227500002.740256 qam24
1Locked40.300
2Locked40.360
3Locked40.340
4Locked40.900
5Locked40.350
6Locked40.350
7Locked40.360
8Locked40.350
9Locked40.350
10Locked38.950
11Locked40.340
12Locked38.950
13Locked40.340
14Locked40.300
15Locked40.900
16Locked40.300
17Locked40.950
18Locked40.350
19Locked40.340
20Locked40.960
21Locked40.3110
22Locked40.950
23Locked40.960
24Locked40.900
13939974245512016 qam3
24619979645512016 qam2
33260000044.5512016 qam4
45369934745.5512016 qam1
3ATDMA0000
4ATDMA0010
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1bddb8d2c5263b88afb9b0a8e8d82604f7fe610b-03-12-2020
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 8
All four of your Upstream Modulations are wrong, they should be 64 QAM.
Your >> BQM << is showing WAN side problems.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
botchok5
  • 13
Message 5 of 8
I've checked all my co-ax cables indoors and outdoors, all are secured.
What I don't understand is that it happened a day after it was working as 'intended'. Nothing has changed from my side since.
The download is so erratic and the upload is more or less non existent. Here's my latest speed test just now after a 5 minute reboot. 387Mbps down, 0.65Mbps up.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 8
In the URL box paste the link you copied and in the ‘text to display’ box write My BQM then click OK
botchok5
  • 13
Message 7 of 8
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 8
Your >> BQM << looks like a noisy line to me.
You can either call in (08:00 is the best time) to report your poor upload speeds or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
