Tomhoplon
  • 9
Message 1 of 17
M350 Speed not achieved
Last time I renewed with virgin, they moved me to the 350 package. Despite this, I've never got above 220Mbs/s.
I have a unifi security gateway plugged directly into the router which is in modem mode. It runs speed tests all the time and confirms this finding:
And yes, it's the same result with a laptop plugged in directly. And the same result in router mode.
This is not really presenting a problem for me but considering it's still slower than the speed it was before the 'upgrade', it would be nice to find out if it can be fixed.
Here are the logs from the box:
Screenshot 2020-05-09 at 21.13.44.pngScreenshot 2020-05-09 at 21.14.04.pngScreenshot 2020-05-09 at 21.14.19.pngScreenshot 2020-05-09 at 21.14.28.pngScreenshot 2020-05-09 at 21.14.42.png
gary_dexter
  • 30.35K
  • 1.88K
  • 4.03K
Message 2 of 17
Re: M350 Speed not achieved
What upload speeds do you get?
SCA1972
  • 5.77K
  • 654
  • 1.93K
Message 3 of 17
@Tomhoplon Your image of the log has been rejected as it contains MAC addresses and this is against the forum rules, to protect your privacy.  If you copy and paste the log the forum will auto censor the MAC address for you when you post it.  There are some unusual errors in there so seeing the full log and these errors in context might be helpful.
Power levels all look to be within the recommended range.
Have you tried different Ethernet cables, to rule out a faulty one?  What spec of Ethernet cable are you using?  Cat 5e should be OK, but there is anecdotal evidence on the forum that the hub might need Cat 6 or higher to consistently deliver the correct speed.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Tomhoplon
  • 9
Message 4 of 17
That's the bottom line in the first graph, about 40Mbps
Tomhoplon
  • 9
Message 5 of 17
Thanks, Top few rows of logs at top.
I've tried a range of cat 6 cables (and 5e).
Tom
10/05/2020 07:52:19noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 21:52:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 17:04:41noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 14:32:6Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 14:32:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 14:32:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 14:31:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 14:00:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
gary_dexter
  • 30.35K
  • 1.88K
  • 4.03K
Message 6 of 17
Your levels are fine.
You say the speeds are the same when wired direct to the hub?
Tomhoplon
  • 9
Message 7 of 17
Yep. I’m not using the Virgin hub for WiFi at all. I’ve tried connecting a laptop to it and using it with my UniFi set up.
SCA1972
  • 5.77K
  • 654
  • 1.93K
Message 8 of 17
Hi Tom
There are some unusual "RCS Partial Service" errors at around 14:30 yesterday but none before or since, so if that was a one off then nothing to worry about.  If that sort of error was to appear in the log every day then it suggests an issue that VM need to investigate.
Scott
Tomhoplon
  • 9
Message 9 of 17
Ok. Haven’t seen that since.
What are the next steps on the speed question.
SCA1972
  • 5.77K
  • 654
  • 1.93K
Message 10 of 17
I'm out of ideas so best to wait for the forum staff to get to the thread and see if their checks reveal anything.
As this is a community forum the system sees a busy thread as one where the community is helping, so every new post puts it to the back of the staff's queue.  So I'd recommend not posting further until one of the forum team gets here.
Scott
