Bulent1903
  • 7
Message 1 of 15
M350: Slow upload speed
Hello all,
I have the 350 package and I get around 370-380 download that's no problem. However, with the upload I get 4mb upload.
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
123500000012.537256 qam13
224300000012.537256 qam14
325100000012.537256 qam15
425900000012.437256 qam16
526700000012.337256 qam17
627500000012.137256 qam18
728300000011.937256 qam19
829100000011.637256 qam20
929900000012.437256 qam21
103070000001337256 qam22
1131500000013.638256 qam23
123230000001438256 qam24
1333100000014.438256 qam25
1433900000014.438256 qam26
1534700000014.438256 qam27
1635500000014.438256 qam28
1736300000014.438256 qam29
1837100000014.538256 qam30
1937900000014.638256 qam31
2038700000014.538256 qam32
2139500000014.538256 qam33
224030000001438256 qam34
2341100000013.938256 qam35
2441900000013.538256 qam36
1Locked37.61883527
2Locked37.62193233
3Locked37.62033044
4Locked37.61852949
5Locked37.31912867
6Locked37.62382899
7Locked37.62292948
8Locked37.62252886
9Locked37.32722740
10Locked37.62522976
11Locked38.62353019
12Locked38.63202716
13Locked38.92252895
14Locked38.63242749
15Locked38.93372564
16Locked38.93582557
17Locked38.64212628
18Locked38.64592680
19Locked38.64702747
20Locked38.64632658
21Locked38.65172550
22Locked38.64872632
23Locked38.64752594
24Locked38.95182346
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
12579999033.5512032 qam6
24620000034.3512064 qam3
33940000034512032 qam4
43260000033.8512032 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
3ATDMA0000
4ATDMA0000
Tags (1)
Bulent1903
  • 7
Message 2 of 15
Re: M350: Slow upload speed
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID780650
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID780649
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
13/10/2020 14:13:8Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:20:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:20:13criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:14:40Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:14:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:14:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:14:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:14:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/10/2020 22:00:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/10/2020 08:21:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/10/2020 12:29:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/10/2020 00:11:39noticeSW download Successful - Via NMS
09/10/2020 00:10:6noticeSW Download INIT - Via NMS
08/10/2020 16:29:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/10/2020 07:27:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/10/2020 15:57:30Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/10/2020 04:29:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 17:53:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 16:29:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 15
Your Upstream Power Levels are way, way too high and an engineer visit will be required to put things right.
You can either phone in (08:00 is the best time) or wait on here for a few days until one of the VM Forum Staff comes along.
Bulent1903
  • 7
Message 4 of 15
Will just call them now - thank you.
Ryan_N
  • 2.09K
  • 104
  • 188
Message 5 of 15
Hi Bulent1903,
Thank you for your post and welcome to the forums.
Not great to see some of the issues you've been having here. Was you able to call the team from your last post? If not don't worry, let me know and I'll take a look 🙂
Cheers.
Ryan_N - Forum Team - https://community.virginmedia.com/t5/custom/page/page-id/WelcomeGoodFolk
Bulent1903
  • 7
Message 6 of 15
Hi Ryan
Unfortunately I couldn't get this issue resolved. I called in couple times and they have not been helpful at all. I have said that my upload speed has been very low and they simply said we don't guarantee upload speeds. I have stated that 4mb is very low and sometimes I get 2mb and also included that I came into this forum and I got told that my Upstream Power Levels are high and an engineer should come and take a look - they simply didn't believe me I guess.
Is there any chance we can book an engineer or something over here or actually get an call-back - ?
Ryan_N
  • 2.09K
  • 104
  • 188
Message 7 of 15
I will send you over a private message 🙂
CHeers.
Ryan_N
  • 2.09K
  • 104
  • 188
Message 8 of 15
Not a problem at all 🙂 Let me know how it goes.
Cheers.
Bulent1903
  • 7
Message 9 of 15
An engineer popped in yesterday, he tried his best to fix the problem but right now I am still getting these speeds - upload is very low
12579984445.7512016 qam6
24619989046.2512016 qam3
33940002646.2512016 qam4
43259996246512016 qam5
1ATDMA004370
2ATDMA0040
3ATDMA0010
4ATDMA00120
Zak_M
  • 4.36K
  • 257
  • 414
Message 10 of 15
Good morning,
Apologies for the delay in response, I have just taken a look into the account using the information you have previously provided to us, I can see that there is currently an SNR outage, this is due to be resolved on the 5th of November. Sorry for any inconvenience this has caused.
Kind regards,
Zak_M
