Hirsty_96
Just joined
Message 1 of 5
M350 Fibre - getting 50-80 Mbs
Tested the connection speed across multiple devices through speed test, power cycled several times and hard reset the router and still getting very slow speeds compared to the 'guaranteed' 181 mbs.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 5
Re: M350 Fibre - getting 50-80 Mbs
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Anonymous
Not applicable
Message 3 of 5
was it a wired conenction with a gigabit network card?
Hirsty_96
Just joined
Message 4 of 5
wireless tests every time, iphone 12 pro then PS5 then work laptop all gave between 50 and 80 mbs returns on the speedtest. Never had issues before qith speed in 2 years but last few days its just dropped off
Anonymous
Not applicable
Message 5 of 5
you must test on a wired test using a gigabit network card.
Wifi has no garanteed speeds
