  • 9.46K
  • 88
  • 599
Hero
Message 21 of 25
Re: M200 worse than / no better than M100
Are you using a MAC or PC?
In device manager> Network Adaptors  select your Network card and right-click to get the menu then left-click on properties
check the advanced tab to read the above
  • 30
Message 22 of 25
Hi Buffer6, its a PC and that particular property is set to Auto Negotiation. Other values are available in the dropdown list.
Hopefully this means something to you!
  • 9.46K
  • 88
  • 599
Hero
Message 23 of 25
Your BBM shows a lot of latency or overutilization, one of the Forum Team will need to look into it
You can check your connection to the Hub speed if you login to your Hub and select devices connected
it should read 1000 if it reads 100 then there is a problem with your connection to the Hub
if it's only connected at 100 it could mean that your PC NIC (Network Interface Card) has  become noisy or gone faulty
and needs replaced or use an external USB3 NIC card
Check that your Hub is placed away from other electrical devices and that all connections are thumb tight
  • 30
Message 24 of 25
Thanks for the reply Buffer6. All of my ethernet devices are showing 1000 so that's good. Devices connected via wifi vary from 4 to 800 odd for the Tivo box.
How do I get the Forum Team to take a look at the latency/ overutilization issue? They seem to have ignored this thread after a brief initial look over a week ago!
  • 9.46K
  • 88
  • 599
Hero
Message 25 of 25
Maybe one of the VIP members will flag this for you
