bazz96
  • 49
Message 51 of 53
Re: M200 wired speed 26.90-56.35
the connection speed is 1Gbps
laptop is 100 mbps
where can i find the cofiguration settings tab please
conman33158
  • 1.41K
  • 121
  • 259
Knows their stuff
Message 52 of 53
So now the laptop is not saying 1Gbps?
So are you saying the laptop it's showing 100mbps and on the hub connected devices it's showing 1000mbps?
To get the configuration tab type in 192.168.0.1 into you url bar and go to router settings. Copy and paste the configuration tab here, just like you done when you put up your router stats.
bazz96
  • 49
Message 53 of 53
I don’t know now I’ll try again today sometimes when connected by cat 7 cable it says 1Gbps and sometimes it says 100Mbps
