bazz96
  • 49
Message 41 of 53
Re: M200 wired speed 26.90-56.35
sams test results
bazz96
  • 49
Message 42 of 53
Latency
30.6 ms
Jitter
17.2 ms
Download
37.5 Mbps
Upload
17.8 Mbps
conman33158
  • 1.41K
  • 121
  • 257
Knows their stuff
Message 43 of 53
Assuming you are using windows 10 can you type in "View network connections" in your search bar bottom left, then right click your Ethernet connection to the USB to Ethernet adapter you just bought and select "Status" What does it say for speed? Should read 1Gbps.
Also, did you turn your wireless off?
bazz96
  • 49
Message 44 of 53
i turned the wireless on the laptop off how do you turn the whole wireless network off please
bazz96
  • 49
Message 45 of 53
peed reads 1.0Gbps
conman33158
  • 1.41K
  • 121
  • 257
Knows their stuff
Message 46 of 53
Now go into your router settings, type 192.168.0.1 into your address bar and go to connected devices and check what speed the laptop is connected at.
conman33158
  • 1.41K
  • 121
  • 257
Knows their stuff
Message 47 of 53
Also while your in the router settings can you copy and paste your configuration tab on here as well.
bazz96
  • 49
Message 48 of 53
rechecked speed now reading 100.0mbps
conman33158
  • 1.41K
  • 121
  • 257
Knows their stuff
Message 49 of 53
This should be 1000mbps, can you also upload your configuration tab please in your router settings as you did not provide this at the start.
bazz96
  • 49
Message 50 of 53
100Mbps
